454 or 496? - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 1st, 08, 06:11 PM Thread Starter
Patrick
454 or 496?
I have a 454 running engine and another 454 bare block. I was wondering if I should change the stock pistons and freshen up the running engine OR buy a 4.25 crank and pistons (i have a set of thumb rods), and build a stroker?
Would it be worth spending an extra 1k + for the 496? Shooting for 650hp. I am going UD solid roller and RR-Ovals.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 6 (permalink) Old Sep 1st, 08, 07:31 PM
Todd
Re: 454 or 496?
It will be alot easier to hit your mark with a streetable combo with the 496. I have a 489 with 9.6 to 1, dart pro 1 heads, .632 hydraulic roller, edelbrock performer rpm, 850 holley, and made around 600/600 on pump gas. Go to a mechanical cam and bump the compression you can get there easily.
Vegas69 is offline
post #3 of 6 (permalink) Old Sep 1st, 08, 07:32 PM
Re: 454 or 496?
I think most people will tell you to go for the 496. There is no replacement for displacement!
buenymayor is offline
post #4 of 6 (permalink) Old Sep 1st, 08, 07:32 PM
Ed
BigBlock1969RS's Avatar
Re: 454 or 496?
If you need a new crank and pistons, 496 would be the way to go for sure. I'm sure you know the saying...
I think you could get even more hp out of a 496 if you are going to go solid roller, just need more aggressive heads, like say the Dart 320cc ones.
Ed
BigBlock1969RS is offline
post #5 of 6 (permalink) Old Sep 1st, 08, 09:20 PM
Wes
Re: 454 or 496?
496,..almost a no-brainer. Scat sells their 9000 series stroker cranks for $299. These cranks are said to be much stronger than cast.
You may need to notch the block a bit for clearance and you may need an oil pan that will clear the stroker crank. No big deal on both fronts.
Good luck!
Straight-line-69 is offline
post #6 of 6 (permalink) Old Sep 2nd, 08, 08:18 AM
Re: 454 or 496?
I'd do it just so I could say "it's a 496"!!!
dubs68camaro is offline
