O/P gauge needle vibrating.... - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 2nd, 08, 03:00 PM Thread Starter
I filled up the '69 this afternoon in order to take it about 20 miles tonight for a car show.
I noticed on the way back home that the oil pressure gauge needle is vibrating like crazy. It still reads good pressure through out the normal street driving range. Has a vibrating 20lbs. @ idle and quickly moves up to 40 just off idle. But the needle is vibrating and seems to respond to rpm change quicker than usual.
I checked the fitting at the back of the block for leaks (its dry). I haven't had a chance to get into the console to check the under side of the gauge. It's a plastic pressure line.
I have a repo console gauge pack on the original console.
Should I be concerned enough to forget about the show tonight?
Any guesses as to what's wrong?
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 3 (permalink) Old Sep 2nd, 08, 03:35 PM
Tim
77wolf10.85's Avatar
Re: O/P gauge needle vibrating....
If it's a new gauge install I wouldn't worry. Sounds like it's missing the pulsation dampener. Some people call it a snubber. Most gauges have a very small orifice at the entry port to knock this out.
Oil pressure does fluctuate, because the ports on the crank do NOT flow to the rods full-time. They are only exposed to oil flow when the port of the main journal enters the groove in the upper main.
If this is a symptom that suddenly developed on an old gauge, the worst case scenario is a spun crank or cam bearing. In which case you could examine the oil filter to ease your worries.
Hope that helps.
Tim Smith
77wolf10.85 is offline
post #3 of 3 (permalink) Old Sep 2nd, 08, 04:48 PM Thread Starter
I just checked the console gauge. I connection has been leaking a little bit. I was able to tighten the nut just a little bit and wipe up the oil that I saw.
I started the engine after putting everything back together. I didn't rev the motor, just let it idle. The needle was steady @ about 35 with the motor semi-cold. I will drive it around the block. If it looks ok I'll head out to the show.
Must make note to cut line and install new farel @ back of gauge.
__________
