Help with powersteering alignment (pics) - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 3rd, 08, 08:01 PM Thread Starter
Darren
What do I have to do to get this to line up correctly? 69 with long water pump, no ac or smog pump.
Darren
67 Camaro 350
69 Camaro 406 10-1 comp, afr 195s, performer rpm intake, 750 DP, comp 286h
67CamaroD is offline
post #2 of 4 (permalink) Old Sep 3rd, 08, 08:09 PM
NHBandit's Avatar
Re: Help with powersteering alignment (pics)
Looks like the correct PS pump so possibly the crank pulley is wrong. How does it line up with the water pump pulley ?
NHBandit is offline
post #3 of 4 (permalink) Old Sep 3rd, 08, 08:29 PM Thread Starter
Darren
Everything else lines up. Alternator and water pump. I have been reading up on adjusting the powersteering bracket. After 6 different pulleys I think I have the correct one now.
Darren
67 Camaro 350
post #4 of 4 (permalink) Old Sep 4th, 08, 06:26 AM
Charlie
I had to make a spacer to place between the P.S. pump adjuster bolt and the adjuster bracket to bring the assembly out. Without the spacer, my pump and pulley sits exactly like yours.
67CamaroRS/SS is offline
