350 or 327 - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 4th, 08, 07:45 AM Thread Starter
350 or 327
the code on my block is 3970010 which comes up as 350 or 327 how do i know the difference???
jonus is offline
post #2 of 8 (permalink) Old Sep 4th, 08, 08:01 AM
Joe
Re: 350 or 327
Need the numbers and letters (engine suffix code) that are stamped into the pad on the block just below the front of the right head.
Joe
'68 SS/RS 350
Never enough time... even less money.
gro51 is offline
post #3 of 8 (permalink) Old Sep 4th, 08, 08:24 AM Thread Starter
Re: 350 or 327
the code is ma30800
jonus is offline
post #4 of 8 (permalink) Old Sep 4th, 08, 08:56 AM Thread Starter
Re: 350 or 327
0
jonus is offline
post #5 of 8 (permalink) Old Sep 4th, 08, 09:48 AM
Re: 350 or 327
I'm not sure if this is right. The code that you gave us, doesn't seem right.
MA 1967 327 manual trans. 210 2 Camaro
Nope: the 3970010 's were not made until 1969
TJS69 is offline
post #6 of 8 (permalink) Old Sep 4th, 08, 09:50 AM
Re: 350 or 327
Need the Engine I.D. Number -top right in pic:
mike532 is offline
post #7 of 8 (permalink) Old Sep 4th, 08, 10:18 AM Thread Starter
Re: 350 or 327
thanks 4 the help i rechecked #s back driver side reads 3970100 and front pass. behind alt. reads ma30800 but it has 4bbl
head reads 3998993
jonus is offline
post #8 of 8 (permalink) Old Sep 4th, 08, 11:06 AM
Re: 350 or 327
Info for the head casting:
1968-76 3998993 350 1.72 1.5 - truck
The block sounds like an over the counter replacement 350. I seem to recall running across the MA designation before. If it was an OE engine installed in a GM vehicle, the assembly stamp would be Vxxxxyy(y) or something similar, and there would be a partial VIN either on the pad or on the flange above the oil filter.
A check of the block date code should confirm it is not a 68 327, and the casting number off the crank would confirm. The bore is the same.
Eric
Eric Kammerer is offline
