new here need help - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 7th, 08, 09:45 PM Thread Starter
new here need help
hi new to this forum but not car's. i have a 87 rx7 with a 95 lt1/700r4.
my problem is that under a load the engine pop's thru the intake.
i've checked all the normal stuff valves,spring's,timing,vacume, you know all the normal problem's. fuel pressure seam's good 30-42psi. opti is working good. any suggestion's???????? thank's in advance
lt1rx7 is offline
post #2 of 5 (permalink) Old Sep 7th, 08, 10:12 PM
clayton hicker
Re: new here need help
flat cam?
clayton hicker
bikedude3 is offline
post #3 of 5 (permalink) Old Sep 7th, 08, 10:46 PM
A pop in the intake is normally the plug firing with the intake valve is open. I had a similar problem recently and I found out that my timing was severely retarded.....just like me!
dubs68camaro is offline
post #4 of 5 (permalink) Old Sep 8th, 08, 12:03 PM
Kyle
You checked the normal stuff eh .. how about location of plug wires in relation to cylinder number? It's not completely out of the ordinary to have a couple plug wires out of order .. thus firing on the intake stroke. You could check that other than that i run straight to a timing/advance issue. That said 95 is a little new for me .
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
GreyShadows is offline
post #5 of 5 (permalink) Old Sep 8th, 08, 08:19 PM Thread Starter
i checked the plug wires. it runs great if your just driving it's only when youget on it just seams to do it under full throttle and what good is a lt1 in a rx7 if you can't play once in awile. the plugs are about 1500 miles old and are still snow white,which is real lean. i'm an old shool carb guy so i don't know sh..t about efi. but i do know its lean just don't know how to fix it.... so i'm hoping someone can point me in any direction
lt1rx7 is offline
