WARNING about Aeroquip Socketless hoses! - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 9th, 08, 01:06 PM Thread Starter
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
If you are using Aeroquip "socketless" (push-lock) hose and fittings, READ THIS!
The hose that Summits, Jegs, and other autoparts places are selling as Aeroquip Socketless hose is apparently the WRONG HOSE and NOT SOCKETLESS. The hose I got from Summit Racing is Aeroquip FC598, and the only place it says Socketless on it is a sticker on the box with the Summit part #. According to the Eaton Hydraulics datasheets, the correct AQP hose for Socketless use is FC332, and it actually says "Socketless" right on the hose. Here's a link to the thread on ls1tech: http://www.ls1tech.com/forums/showthread.php?t=934214
Btw, does anyone know someone at Summits, Jegs, etc or Eaton Hydraulics?
- LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Rodder is offline
post #2 of 6 (permalink) Old Sep 9th, 08, 01:22 PM
Jody
camcojb's Avatar
Re: WARNING about Aeroquip Socketless hoses!
could be a big issue as the id's are not the same between push lock and regular assembled hose, and using the wrong one on push lock could cause it to exit the fitting...................
Jody
camcojb is offline
post #3 of 6 (permalink) Old Sep 9th, 08, 01:47 PM Thread Starter
Jon
Rodder's Avatar
Jody
Yeah, and that'd be A Really Bad Thing (TM) anywhere downstream of a 255lph fuel pump...
Rodder is offline
post #4 of 6 (permalink) Old Sep 10th, 08, 05:54 AM
Rick
Hmm. I have two boxes of the stuff I've been using. No issues after 3 years. I'll check tonight. Good catch!
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #5 of 6 (permalink) Old Sep 13th, 08, 08:28 PM Thread Starter
Jon
Rodder's Avatar
Someone claiming to be from Aeroquip just posted in the Welcome Wagon forum and said the FC598 is socketless after all... I just dropped him an email asking for an explanation of their datasheet.
https://www.camaros.net/forums/showthread.php?t=141608
Rodder is offline
post #6 of 6 (permalink) Old Sep 14th, 08, 08:50 AM
Banned
Rob
satz28's Avatar
The 200 deg, maybe be the fluid temp they are referring, and not the ambient temp.
Many times hose and pipe ratings are based on the fluid temp/fluid pressure.
satz28 is offline
