Help - Team Camaro Tech
post #1 of 19 (permalink) Old Dec 15th, 08, 10:48 PM Thread Starter
Help
ok i guess u can can help me out
today i bought a 1998 camaro 3.8 v6 series 2
firday i test drove it everything was fine car blew out heat
ran good but need a belt..everything was great no engine check light i live in milwaukee the car was bout 100 miles way...
temps dropped very low out here -16 wind chill colder up north
so i get the car monday n theres a problem cars not blowing out any heat
didnt think to much of it cause it was cold outside waited 10 mins decided to get on the highway to drive back home...filled the tank up but while im waiting the car starts to rev on its on..now ive asked the man about an oil change n he said about a month ago but he hasnt been driving the car...so i thought it was all good..now back to the freeway. im doing 70 then the car starts making weird noises like there's something loose on the engine sounds like a chain or something still no heat..the car starts to die i pull over side of the road n the engine cuts off( the engine has been replaced 60,000 miles on it)i leave it sit for a while try to crank it over again it starts but i head knocking now put more oil n the car n the car starts to smoke...so i let it run for a while n itcuts off again..now when i try to put it n drive i hear knockin n a raddling sound from under the hood..not sure wats going on but my cuzin says it could be a bent crack shaft.....some one help me
Acewille is offline
post #2 of 19 (permalink) Old Dec 16th, 08, 03:36 AM
Kevin
SixtyAte's Avatar
Re: Help
Sounds like you ran the car without antifreeze and overheated it. It may have had a leak without you knowing it or even a blown head gasket. Check fluid levels. You may have roasted the motor
Kev
SixtyAte is offline
post #3 of 19 (permalink) Old Dec 16th, 08, 08:54 AM
Re: Help
You said you added more oil. Did it need it? If that engine used that much oil and blows no heat because the antifreeze is gone you need to get your money back.
deerhunter is offline
post #4 of 19 (permalink) Old Dec 16th, 08, 09:48 AM
BILL
SPARKY69's Avatar
Re: Help
Did the block freeze???
SPARKY69 is offline
post #5 of 19 (permalink) Old Dec 16th, 08, 10:42 AM Thread Starter
Re: Help
i put more oil n the carn the gauge went to like the middle of the oil gauage..im going to trn to put some antifreeze n the car that car ran for about 30 mins last night with no problems but still no heat blowing out
Acewille is offline
post #6 of 19 (permalink) Old Dec 16th, 08, 10:43 AM Thread Starter
Re: Help
how do u know knoe if the block freeze?
Acewille is offline
post #7 of 19 (permalink) Old Dec 17th, 08, 04:54 AM
BILL
SPARKY69's Avatar
Re: Help
Well.. If you got it running the block proball didnt freeze....you might want to pull the therm. Out and make sure you have got a.f in the block and run it with out a therm. Also check the heater control valve by the firewall to make sure its sliding back and forth...
SPARKY69 is offline
post #8 of 19 (permalink) Old Dec 17th, 08, 06:27 AM Thread Starter
Re: Help
new news last night i had it running fr about n hour put 2 more quarts of oil n the car...i olny put 2 n on tha high was tha car ran fine..but there was a loud noise once it started i dont think the fan was spinning..also theres a whole n the antifreeze it leaked all over the floor the oil gauge is n the middle now...the engine got hot but still no hot air was blowing out...i put the car n drive n i could feel tha car shaking..exhuats was clear i didnt see any white exhuast after awhile..theres kinda of a knockin noise also
Acewille is offline
post #9 of 19 (permalink) Old Dec 17th, 08, 08:15 AM
Re: Help
You need to keep a very close eye on the oil level! Is it overfull now? It sounds like you have added 4 quarts of oil in very few miles! That means it only had one quart of the 5 required! If the fan isn't turning, that could mean the water pump isn't turning either. If the water pump isn't turning you won't get any heat out of the heater. It also means you are destroying the engine due to overheating! Check your belts! IF the belts are good, make sure the oil level is full and the radiator is full, then start the car with the radiator cap off and see if the water is circulating when the water temperature is up to normal. If everything checks out, you might then need to backflush the heater core before the hot water can circulate. First things first though, you really need to cure the oil consumption and loss of antifreeze problems first or it won't matter if the heater works or not because your time will be spent replacing the engine!
post #10 of 19 (permalink) Old Dec 17th, 08, 08:55 AM
BILL
SPARKY69's Avatar
Re: Help
Where did the af leak out...you said the floor(garage floor or the floorboard of the car?) if it leaked out the floorboard possible Heater core..ELECTRIC FAN OR CLUTCH FAN?? SHOULD BE ELE.also look for the weep holes at the water pump, should be two of them, see if its wet or leaking there..
SPARKY69 is offline
post #11 of 19 (permalink) Old Dec 17th, 08, 10:40 AM Thread Starter
Re: Help
naw its about 4 quarts of oil n it..the man told me that the water pump is new n so are all of the wire ect..all my belts are good..how do i flush the radiator...the antifreeze is on the garage floor electric fan..should i get the radiator flused at fast track or something..also when i cut the ar off it sounded like it was drink something like swallowing a fluid..
Acewille is offline
post #12 of 19 (permalink) Old Dec 17th, 08, 11:38 AM
BILL
SPARKY69's Avatar
Re: Help
sounds like an air pocket in the cooling system.. if its gurgling..get a flush done thatll get to the bottom of that....and it will release any air pockets...air pockets cause no heat..(p.s. change the oil and start from the beginning with that too....)
SPARKY69 is offline
post #13 of 19 (permalink) Old Dec 17th, 08, 12:13 PM Thread Starter
Re: Help
also the check engine light is on...it stays on for a while then it flashes....how can i flush the radaitor
Acewille is offline
post #14 of 19 (permalink) Old Dec 17th, 08, 12:15 PM Thread Starter
Re: Help
this is my first camaro
Acewille is offline
post #15 of 19 (permalink) Old Dec 17th, 08, 03:01 PM
BILL
SPARKY69's Avatar
Re: Help
if the check engine light flashes its a misfire code....means a its not running on all 6....you can flush the rad by pulling both hoses off (at the top of the rad. and the bottom) and running a garden hose at the top and let in run out the bottom...(TILL YOU SEE CLEAN WATER)
SPARKY69 is offline
