Flywheel Bolt Clearence - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 16th, 08, 06:27 AM Thread Starter
Post Flywheel Bolt Clearence
How much clearence should there be between the flywheel bolts and the block while they are torqued to spec to the flywheel flange? I am using new stock flywheel bolts with the correct lock washers. The bolts are only about a 40 thousanths of an inch from the back of the block casting.
Thank for the help.
69camaro1 is offline
post #2 of 8 (permalink) Old Dec 16th, 08, 07:03 AM
Re: Flywheel Bolt Clearence
I dont have the measurements, someone here will probably give you that, but the difference might be flexplate vs flywheel. Flywheel bolts are longer.
1969 Camaro, 548ci, 10.6:1, solid roller, Ford AOD, 4000 Stall, 12 bolt with 4.11's
New best, 10.59 at 125.48, 1.39 60ft
Cali Z28 is offline
post #3 of 8 (permalink) Old Dec 16th, 08, 05:10 PM
Right, they are shorter for a flexplate and longer for a flywheel.
pdq67
post #4 of 8 (permalink) Old Dec 16th, 08, 05:37 PM
Bill
69,
If it is an automatic flywheel, and you have the correct bolts, they really should not come out of the crankshaft flange much at all. The threads on the correct bolts are probably less than 1/2" long. Sounds like you may have bolts for a manual transmission flywheel.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is online now
post #5 of 8 (permalink) Old Dec 16th, 08, 07:12 PM
Originally Posted by BillK View Post
69, they really should not come out of the crankshaft flange much at all.
Either set-up, flexplate or flywheel, bolt should have less than two threads showing on the block side of the crankshaft flange.
post #6 of 8 (permalink) Old Dec 16th, 08, 07:16 PM
For those longer bolts sticking out of the threaded hole, remember the crank will walk a few thousands, if you thrust bearing surfaces are good.
TC # 349
zdld17 is offline
post #7 of 8 (permalink) Old Dec 16th, 08, 08:06 PM Thread Starter
Thanks for all of the help. Just to clarify it's a manual trans flywheel, not an automatic trans flexplate.
post #8 of 8 (permalink) Old Dec 17th, 08, 08:50 PM
.gearhead.'s Avatar
Did you use spacers?
Then: N/A, 436 ci, Stock Block, Track 1's, Stock Suspension, Ranchos, 3250 lbs... 1.33 60 ft / 9.69 @ 138 mph
Now: Boost...
.gearhead. is offline
