Engine Vacuum - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 16th, 08, 07:56 AM Thread Starter
Ken
Engine Vacuum
Assuming I do not have a vacuum leak, which I'm sure I do not, Is there a way to increase engine vacuum? I thought I read something one time on how to add vacuum by adding a stand alone source.
Its been a while since I checked, but when using a vacuum gage, my motor was not in the normal range. I do have to much cam, in addition to still running the original exhaust manifolds and not headers. I just like the lumpy idle I get.
1969 SS/RS 350 Hugger Orange
kencar69 is offline
post #2 of 8 (permalink) Old Dec 16th, 08, 08:32 AM
Charlie
Re: Engine Vacuum
I run Rhoads variable duration lifters and IMO, they are the best way to increase vacuum, but they are for hydraulic cams. They will work on solid cams, according to Rhoads, but some say they defeat the purpose of a solid cam. The vaccum tanks are ok, but they can still run down. What exactly are you trying to get more vacuum for? Brakes? If brakes, then make the switch to hydroboost. Best thing you will ever do.
67CamaroRS/SS is offline
post #3 of 8 (permalink) Old Dec 16th, 08, 10:01 AM
Re: Engine Vacuum
Increase initial timing and curb idle.
post #4 of 8 (permalink) Old Dec 17th, 08, 04:29 AM Thread Starter
Ken
Re: Engine Vacuum
Most part everything is OK, brakes are a little soft at first but are good. Was thinking low vac could be the reason my RS lights dont function to well.
kencar69 is offline
post #5 of 8 (permalink) Old Dec 17th, 08, 04:36 AM
Re: Engine Vacuum
A vacuum gauge hooked to intake manifold (full time) indicates _______in. of vacuum.
An OE Z/28 comes standard with a brake booster and with the RS option, the engine creates 9 in of vacuum. I think there is a reservior with a check valve inside the drvr fender by the firewall to assist the headlamp doors.
post #6 of 8 (permalink) Old Dec 17th, 08, 07:40 AM
Charlie
Re: Engine Vacuum
For that you need to make sure all the hoses are in good shape. That is the reason A LOT of 68/9 RS owners are converting theirs to electric doors. The time consumed maintaining the vacuum hoses is a PITA. That is 1 of the good things about a 67 RS. Provided you have a hydraulic cam, the Rhoads variable duration lifters will increase your vauum up to 5".
post #7 of 8 (permalink) Old Dec 17th, 08, 09:08 AM
Re: Engine Vacuum
Another common problem is that the RS headlight hinge and door bushings are worn out and binding, a little lube also helps as they tend to get sticky as well with road dirt and dust.
I just fixed 1 the other day and it had spit hoses at the lower actuators.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #8 of 8 (permalink) Old Dec 18th, 08, 05:26 AM Thread Starter
Ken
Re: Engine Vacuum
Yeah, I already picked up a bushing kit for the doors, just havn't replaced them yet. At present my doors will open, but without assistance they won't close.
kencar69 is offline
