Re: Intake Manifold Gasket Question
Just use a little bit of some good quality rtv around the water ports, I prefer Ultra Black myself. You can also use just a dab of yellow weatherstrip adhesive just to hold the side gaskets form slipping, usually the size of a match on the side of the outer intake ports.
The intake gasket sets are embrossed with a raised section around the ports so no sealer is required unless you have some gasket surface imperfections.
The weatherstrip adhesive is nasty ( we used to call it Yellow Death ), Good Luck getting the gaskets off if you use too much, you will be cursing and scraping for hours. JMO.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
