Oil pans - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 18th, 08, 10:46 AM Thread Starter
seeburg220's Avatar
Oil pans
I have a '70 Corvette oil pan for my 350 I wanted to use. Will it fit in my '69, or is it too big? I have the engine out now, so I can't measure the crossmember and steering link. Thanks.
1969 / 350 / TH350 / 3.73 posi / driver
seeburg220 is offline
post #2 of 5 (permalink) Old Dec 18th, 08, 10:55 AM
Re: Oil pans
Nope it wont fit, unless it is the superceded GM part number that is a 5 quart L82 pan , the same as a 69 Z28.
Post a picture and I will tell you for sure.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #3 of 5 (permalink) Old Dec 18th, 08, 06:09 PM Thread Starter
seeburg220's Avatar
Re: Oil pans
post #4 of 5 (permalink) Old Dec 18th, 08, 07:10 PM
Joe
Re: Oil pans
If I am correct, I believe the bottom of that pan would hit the crossmember of a 69....
OK69 is offline
post #5 of 5 (permalink) Old Dec 18th, 08, 07:17 PM
Re: Oil pans
Yes and the drag link. That is a std 65-74 corvette pan and also 69 350/350HP as well as others.
rszmjt is offline
