Engine Choice - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 19th, 08, 10:41 PM Thread Starter
Question Engine Choice
Here's the deal. I have a pretty strong engine (383, 12:1 compression pushing about 450 hp).
My goal is to have an engine with similar hp that is more reliable, less maintenance and runs on pump gas.
I was thinking about an LS engine but it seems like they are really expensive (10K+ for total swap) and require a lot of modifications to the vehicle (68 camaro). Is this an accurate statement?
I was looking at a crate engine built by Edelbrock that seems to fit the requirements but I think it is about $7500. With that kind of money the LS seems like a better option, right?
So perhaps I can work with what I have, even then the EFI conversion is about 3K. My current engine has solid lifters so I would also need to swap that out for a roller cam and different pistons to change the compression. So even using my existing engine I might be hitting $7500.
I guess this is a really complicated way of asking what would be the best way to get an engine with 425+ hp and gets decent MPG?
Thanks,
MTmace
MTmace is offline
post #2 of 9 (permalink) Old Dec 20th, 08, 01:41 AM
Harley
wiskeesour's Avatar
Re: Engine Choice
Mass-Flo EFI on top
10.5cr with Dynamic around 8.1:1
AFR Elim 195 heads
XR282hr..EDIT: I was thinkin, that cam maybe a XE274HR. Cant remember.
and it gets 17mpg with a 5speed. mathematically, should get 21mpg with a 6speed if we can keep the same VE.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 9 (permalink) Old Dec 20th, 08, 03:37 AM
Re: Engine Choice
Heck, a no-brainer by me!
A cheap 496 that's around 550 hp at 5500 rpm!
Like my old "tow-truck" motor!
And fwiw, I figure I am like just a couple a hop up's away from 650/700 hp if/when the dreaded, "More power, Scotty" bug bite's me!!
pdq67
post #4 of 9 (permalink) Old Dec 20th, 08, 05:38 AM
Dave C
Re: Engine Choice
We just bought a fresh 463 BBC 675 hp pump gas motor for my sons Chevelle for $3500.I think there are deals to be found out there that you can find for less tha 10K I would keep shopping.May be a BBC is not what you want but they have a nice tone and look under the hood.
My sons motor:
My engine compartment:
Just a couple pics for a decision.I almost went with a small block but I am kinda glad I went with the BBC.
PRO.ST69orange
post #5 of 9 (permalink) Old Dec 20th, 08, 06:30 AM
Patrick
Re: Engine Choice
I am also swapping my 383 for a big block.
Your engine is capable of making 500hp on pump gas easy. What heads do you have?
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #6 of 9 (permalink) Old Dec 20th, 08, 08:45 AM
Shawn
Re: Engine Choice
yeah stick with the old school SBC
i hate when people put lsx engines in old camaros, totally takes the fun out of the car IMO
plus a bone stock ls1 doesnt really make impressive hp numbers.
victimizati0n is offline
post #7 of 9 (permalink) Old Dec 20th, 08, 10:46 AM
Re: Engine Choice
AND DON'T CALL THE LS-, A SB!!
pdq67
post #8 of 9 (permalink) Old Dec 20th, 08, 11:50 AM Thread Starter
Re: Engine Choice
Thanks for all the replies, I think I will stick with what I have.
I was a little skeptical that you can get the high MPGs from an old school block.
But with the money savings it might be worth a shot.
The heads are 202.
MTmace
MTmace is offline
post #9 of 9 (permalink) Old Dec 20th, 08, 11:56 AM
Re: Engine Choice
The deal w/ gas mileage by me is DRIVING like you have a raw egg between the ff and your foot!
Putz around like an ol' man and run 58 to 62 mph on the hwy w/o the A/C on and I will bet a 6-pack of your fav. "barley-pop" that you will get at least 20 percent better gas mileage b/c I know I can and have done!
pdq67
