3932472 Aluminum Manifold Care? - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 20th, 08, 11:28 AM Thread Starter
mch6970ss's Avatar
I have a factory aluminum manifold on my 69. It looks great after it has been bead blasted. Can anyone give me advice on how to keep it looking that way without spray paint?
mch6970ss is offline
post #2 of 6 (permalink) Old Dec 20th, 08, 12:11 PM
DjD
DjD's Avatar
Re: 3932472 Aluminum Manifold Care?
What's the aversion to paint? A light dusting of cast blast silver will fill the open pores the bead blasting created, it will look closer to a factory finish and spills will wipe right off.
I have had good luck using Never Dull wadding on alternators and other less porous parts but fresh bead blasted cast parts just want to soak up dust, grease and fluids...
...Dennis
DjD is offline
post #3 of 6 (permalink) Old Dec 21st, 08, 08:11 PM
Brent
Brentmc's Avatar
Is powdercoating a good option here?
1968 RS/SS Lemans Blue
Brentmc is offline
post #4 of 6 (permalink) Old Dec 21st, 08, 08:29 PM
Send a message via AIM to RamAirDave
If it was blasted at low psi, follow it up with a good rubdown of steel wool. Clean up will be a snap, just a quick wipe with a wax/grease/silicone remover.
I think the problem with blasting is when done at high psi, but have never done one that way. Ive done a handful or so the last few years and staining, discoloration, difficult clean up, etc. is a non-issue. And that's not even cleaning up right away as I've gone back after months of heat cycles and still no problem.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #5 of 6 (permalink) Old Dec 22nd, 08, 09:28 AM
Brett
I use plasti-kote brand clear 500 deg. with great results. Looks great for years.
Brett
gm torch red is offline
post #6 of 6 (permalink) Old Dec 22nd, 08, 10:25 AM Thread Starter
mch6970ss's Avatar
I guess I forgot what the manifolds looked like when they were factory new. I assumed the fresh beadblast look was the same. Do you think a clear paint or the cast blast would be a more original look?
