Re: power steering pulley not lineing up??
1) 67,68 short water pump pulley's are ALL different than the 69 Long water pump pulleys.
Yes, this does include power steering pump pulleys !
2) All 67,68 short water pump Accessory brackets are all different than the 69 Long water pump accessory brackets.
3) 67,68 big block engines used different pulleys and accessory brackets than the 67,68 small block engines.
4) 69 big block engines used different pulleys and accessory brackets than the 69 small block engines.
That is 4 different combinations, that if combined will cause you problems.
