bb frame stands - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 22nd, 08, 02:27 PM Thread Starter
bb frame stands
guys, have a customer project in the shop and am installing his numbers matching 396. I bought some reproduction frame stands for 69 bb. I have energy suspension mounts on the motor and if one mount is lined up the other is at least a full bolt hole off???
frame stands heights are-
dr. side- 1-3/4
pass side- 1-1/2 from frame to center of frame stand bolt hole.
did i get the wrong mounts? its almost as if the dr side frame stand needs to be 3/4 longer towards pass side so everything lines up?? what mount to get?
1968 Camaro streetfighter, 18x10,18x12 ccw's,tq arm rear,apex c6 front sub,ls6 asa cammed dry sump,t-56,335/30/18 and 275/35/18 toyo r888
Jake's Rod Shop
207-595-0677
BBCamaro is offline
post #2 of 2 (permalink) Old Dec 22nd, 08, 02:54 PM
Ed
Re: bb frame stands
This might help, good source of information
http://www.pozziracing.com/camaro_engine.htm
freezined is offline
