cam & heads - Team Camaro Tech
post #1 of 17 (permalink) Old Dec 23rd, 08, 06:30 PM Thread Starter
harvey
cam & heads
I'am new on here and wanted to know if u guys could give me some advice i have a 77 355 chevy S.B. it has world prod S.R. 194 heads that are ported, manifold is 300-38 street domnator ,the carb is 700 holley D.P. W/9.81 COMP THE CAM IS A 272 POWERMAX CRANE cam 216-228 dur w/a 454 480 lift w/12 bolt w/373's it's a strret and strip S10 i wanna go to a bigger cam like a solid flat tapped should i put bigger valves like 202 would that help i know the manifold is weak i'am gonna change that next spring. thanx
P.S. RIGHT NOW IT'S RUNNING 13.19 AT 102 M.P.H. IN THE QUARTER
pink panther is offline
post #2 of 17 (permalink) Old Dec 23rd, 08, 06:44 PM
Ron
Re: cam & heads
I think you're good to go as you are for Pump Gas. I suspect your cam is a Hydraulic FT. Yes you can get another 1000 rpm with a Mill on the Heads to up the Static Compression to say 11:1 and run either a Mechanical FT or Solid Roller Cam; BUT, your LOW END will Suffer on the Street and in my opinion NOT worth the tare down and $1500 for a SR or I might agree to $200 mechanical FT with a slightly longer duration and lift. As for as Valve size the 1.94's/1.55 are sufficient, if that's what you have. You don't need 2.02/1.6's until over 6500 rpm.
If anything I would swap out that 300-38 street domnator intake manifold for an Eldelbrock Dual Plane RPM and run a Holley 650 Dp if your tranny is manual or a vacuum 650 Holley if the tranny is auto , a 750 Dp if you plan hitting 7000+rpm and the Crank, Rods and Pistons are forged in which case the Single Plane would benefit with a bigger cam and then consider spending more bucks for the 2.02/1.6's and Machinists Shop Time. Then again your Street Performance will suffer ;o)
I run a 454 like a 302 and don't consider 1/4 times - so what's a Z28 all about if you can't shift to 2nd with a M21 or 2 at 65 mph. Sh*t a 68 Volvo B20 could do it at 80mph with 3.90 gears - you might not have a clutch left, if you do it on asphalt, but what the H*ll - LOL
There is nothing like shifting into any gear including 2nd while cursing on the freeway and anticipate on how to over take your prey with the engine humming, whether it is a 302 or a 572.
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 17 (permalink) Old Dec 23rd, 08, 07:22 PM Thread Starter
harvey
Re: cam & heads
sorry i forgot to say that it is 350 tubo w/a 2800-3200 stall
post #4 of 17 (permalink) Old Dec 23rd, 08, 07:54 PM
Ron
Re: cam & heads
Other then changing out the Intake to an Edelbrock Dual Pane RPM and Holley 650 vacuum, as you're running an Auto-Tanny, you're good to go, without a cam change, in my opinion ;o)
Z15CAM is offline
post #5 of 17 (permalink) Old Dec 24th, 08, 03:54 AM Thread Starter
harvey
Re: cam & heads
i was wondering if u had any idea what kind of horsepower and tork i have w/ this combo it is a 700 mech D.P. just curious
post #6 of 17 (permalink) Old Dec 24th, 08, 05:45 PM
greg
Re: cam & heads
In a Hot Rod magazine cam comparo a 350 RHS 8.8cr motor with S/R heads and with a Comp 275 DEH 219-229 .468-.488 lift, 110 lsa cam and a 750 DP made 330 hp at 5000 rpm and 390 lbs. of torq. at 3500. They also tried a Comp 282S solid lifter cam-236-236 .495 gross lift 110 lsa lashed at .024 and it made almost identical hp and tq figures from low end to top end. Your cam would be comparable to the 275 DEH cam in my opinion.
docwilcar is offline
post #7 of 17 (permalink) Old Dec 25th, 08, 01:55 AM Thread Starter
harvey
Re: cam & heads
gee i would'nt think i would run that fast w/only 330 H.P,i can give up some tork since it's only 3000 p.d.s. been thinking about getting a cam in the 240- 242 dur, little over 500 lift and still have enough bottom end tork.
post #8 of 17 (permalink) Old Dec 25th, 08, 12:39 PM
greg
Re: cam & heads
If you left your cam in there an put some bigger heads on it you could get up around 380 or more hp. Another Hot Rod cam article on a 350 at 9.7 cr with AFR 190 heads made 380 hp at 5400 and 400 #tq. at 4100 with the little 218 duration Comp 268HE cam. The 280 Comp cam made 405 hp at 5700 and 404 lb. ft. [email protected] 4300. Vacuum was 12.5 inches at 850 rpm. If you want a bigger cam without changing heads I think you will not be very happy with the results. If you want a different cam try one on a 108 lsa for more low and midrange punch like an Isky 270 mega cam or Crane 274H06 on a 106 lsa.
post #9 of 17 (permalink) Old Dec 25th, 08, 08:14 PM Thread Starter
harvey
Re: cam & heads
well it's gonna be awhile before i get new heads i have to narrow my rearend a 69 z-28 12 bolt w/373's so that well take about a 1100.00 to do that maybe next year on heads.
post #10 of 17 (permalink) Old Dec 26th, 08, 10:44 AM
Re: cam & heads
DO NOT CUT THAT REAR END for that kind of money you can do a 9 inch ford if you want to find out how PM me i will tell you
ssdoug is offline
post #11 of 17 (permalink) Old Dec 26th, 08, 11:06 AM Thread Starter
harvey
Re: cam & heads
i want to stay all gm i looked at the numbers and it started as BU on the rearend after i did some research i guess the guy i got it off was telling truth.what year camaro do u have? take care Harv
post #12 of 17 (permalink) Old Dec 27th, 08, 03:34 AM
Re: cam & heads
I have a 68 SS thanks for asking -Doug
ssdoug is offline
post #13 of 17 (permalink) Old Dec 27th, 08, 12:30 PM Thread Starter
harvey
Re: cam & heads
do u have a smallblock or a big block in that?
post #14 of 17 (permalink) Old Dec 28th, 08, 06:19 PM
Re: cam & heads
small block 406-tko 600-9 inch-3.55 detroit locker.
ssdoug is offline
post #15 of 17 (permalink) Old Dec 28th, 08, 06:39 PM Thread Starter
harvey
Re: cam & heads
been thinking about puting a detroit locker in my 12 bolt how are they on the street like around corners and such? also i always wanted a 391 stroker thinking about stroking out the 355 everybody does a 383 i want to be different, i've heard that they are a torker motor the 406 cool. Harv
