double pumper... - Team Camaro Tech
post #1 of 27 (permalink) Old Dec 23rd, 08, 07:06 PM Thread Starter
double pumper...
i am thinking of going with a Holley 750 double pumper with mech. secondaries on my 67 camaro. i was told that with the horsepower, manual transmission, and 4.11 gears i have that my car would perform a lot better with a double pumper. right now, it kind of studders off the line. i currently have a edlebrock 750 with vacuum secondaries. what do you guys think?
1967 Camaro RS
383 Stroker 427HP 457TQ
Tremec TKO-600
Strange Engineering 12-Bolt 4.11 Posi
Coys C-55 18" Wheels
Scott MH is offline
post #2 of 27 (permalink) Old Dec 23rd, 08, 07:16 PM
jeff
1SLOW64's Avatar
Re: double pumper...
get rid of the edeljunk! My car leaves like a bear with a 750DP
1969 X66 PROJECT:
2002 C5 COUPE ELECTRON BLUE SOLD
1987 BUICK GRAND NATIONAL SOLD
1964 CHEVY II 406 SOLD
1SLOW64 is offline
post #3 of 27 (permalink) Old Dec 23rd, 08, 07:58 PM
I run double pumpers on that type of application and a heavy betty with an auto trans. I love them on everything!!!!
dubs68camaro is offline
post #4 of 27 (permalink) Old Dec 23rd, 08, 08:09 PM
george
Nuthin hits the tires harder than a dp.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #5 of 27 (permalink) Old Dec 23rd, 08, 08:15 PM
Logan
Would it be alright to run a double pumper with an automatic trannny and stock 3.08 gears
Camaro55 is offline
post #6 of 27 (permalink) Old Dec 23rd, 08, 08:27 PM
I like DP's a lot, on nearly any fiarly high HP application, but...
If your stick shift car stutters leaving a light with an ede, something is wrong and it ain't the carb. Tuning issue, or perhaps a clutch problem.
post #7 of 27 (permalink) Old Dec 23rd, 08, 08:44 PM
george
The OP shared some of his combo for consideration.Your question is very vague.Example..I have a 572 bbc in a 3200 lb Ist gen camaro with an auto and 3.08 rear gear.Would it be alright to to run a double pumper?Yep to that.Whats your combo????
George
68 Camaro
fatblock is offline
post #8 of 27 (permalink) Old Dec 23rd, 08, 08:44 PM
Harley D
HarleyD67's Avatar
not realy. You'd be better off with a vac. sec. 4160 with that high gear. Even with a manual matched to that gear I'd say stay with a vac. sec.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #9 of 27 (permalink) Old Dec 23rd, 08, 08:47 PM
Harley D
HarleyD67's Avatar
Like Jim said something is causing the studder. It may be the carb needs tuning or could be something else, but to answer your question a dp is a very good match to your set up. We would need to know more details before recommending a size.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #10 of 27 (permalink) Old Dec 23rd, 08, 08:56 PM
george
750 cfm dp atop a 425 hp 383 stroker is a perfect fit imo.Been there done that with great results.Not to big.not to small.
George
68 Camaro
fatblock is offline
post #11 of 27 (permalink) Old Dec 24th, 08, 09:21 AM Thread Starter
well i guess i shouldnt have said off the line, it will take off hard off the line but if i am at 35-60 and in 3rd or 4th gear and floor it, she shudders
also, i have a TorkerII manifold and i am also thinking of changing over to a air gap manifold with a 1" spacer...
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
post #12 of 27 (permalink) Old Dec 24th, 08, 10:20 AM
Harley D
HarleyD67's Avatar
What's the cam specs? Although unless it's real mild with the vastly improved manifold swap you plan I would suggest a 750dp as well. Is this a daily driver that you would need a choke? If not and you can at all swing the slight extra cost go with a Proform or Quickfuel carb. The improved air and fuel flow not to mention the large glass site windows make it a much better carb. If you do go with a Proform or Quickfuel though get a 700 as they flow higher than rated. There 750 actually flows 780-800cfm, and I think the 700 is around 730-740cfm. As for the hesitation now that you describe it better it does sound more carb related. Probably in the needles somewhere, but as I'm a Holley man and haven't really played with AFB carbs since high school I can't tell you how to fix your "ede".
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #13 of 27 (permalink) Old Dec 24th, 08, 12:51 PM Thread Starter
the cam i am running is a Comp Cams Extreme Energy Flat Tappet 230/[email protected] the car is a daily driver but i do not currently have a choke and it runs fine. however, i do plan on adding a manual choke to my system, for those just in case days. i am looking at the holly 750 kit from jegs http://www.jegs.com/i/Holley/510/0-4779SK1/10002/-1 i was interested with the quick fuel carbs because my dads 472 Hemi funs a 1050 Quick Fuel. they are good looking cab thats for sure however they are pretty darn expensive
1967 Camaro RS
Tremec TKO-600
Scott MH is offline
post #14 of 27 (permalink) Old Dec 24th, 08, 02:39 PM
I went from a VS750 Holley (with a lot of work) to a DP750 Holley.... really made a big difference
68 Camaro~LSx ~all motor
post #15 of 27 (permalink) Old Dec 24th, 08, 06:13 PM
Harley D
HarleyD67's Avatar
If you want a choke then go with this and just get the line separate.
http://www.jegs.com/i/Proform/778/67213/10002/-1
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
