Carb issues - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 24th, 08, 12:46 PM Thread Starter
Brandon
Carb issues
Hey guys new issue for me now.
Changed out the cam from theCc 270H as a lifter locked up and ate a lobe.
So changed out to a summit cam .465/.465 282 duration w/ 114 lobe separation. Not as steep as the CC270H but a bit longer duration.
So after this I dropped from the 750 vac sec to a 670 street avenger as the 750 was too much. I just got done rebuilding the 670 last night with all new gaskets, needle valves, the works with a new holley kit.
So, now getting it started was fun as I ended up having to nearly max out the idle to get it to stay running at what I believe to be near the 850rpm area. The exhaust smells of unburnt fuel and is somewhat black. Trying to set for best vacuum has got me stumped on this one. Given that it's a longer duration cam I know the hg would drop but not to the 6hg level. Opening and closing the needles hasn't had any effect. Finally I pulled the vacuum line off the carb from the guage and suddenly the rpms go up and she idles better.
So I'm asking if it's possible that the primaries are too closed up and need to be opened somewhat from below to allow for more air flow?
Now that's about all the info I've got on it at the moment
Brandon J. licence 1NASTY67
Nantooch is offline
post #2 of 4 (permalink) Old Dec 24th, 08, 01:22 PM
Re: Carb issues
Ignition lead would help. See if the secondaries have a setscrew on the throttle shaft/bracket/base to open them just a hair. I use a feeler gauge to assist, then after done, screw out the screw and start it from the top of the throttle base plate for easier access, or not.
Any action to get the priimary throttle plates closed so idle mixture screws can have an influence
post #3 of 4 (permalink) Old Dec 24th, 08, 04:21 PM Thread Starter
Brandon
Re: Carb issues
Got it figured out. Partly to blame was the secondaries being open, fast idle was messed up, but I think the bigger part was that the gasket between the metering block and the carb base on the primary side had a slight tear in it. Straightend out those items and vacuum went to 13 and car idles with barely any idle and the set screws definately have influence now.
Nantooch is offline
post #4 of 4 (permalink) Old Dec 25th, 08, 05:28 AM
Re: Carb issues
Cool !!
