Alternator Brackets help wanted - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 24th, 08, 05:33 PM Thread Starter
Ruben
I need help finding brackets for the alternator to mount on the driver's side. I am not looking for factory due to the fact that I am running hooker headers. Also, I am trying to run a serpentine belt setup. The AC unit is bolted on the passenger side. This is a '69 camaro small block. Any help would be appreciated. Thanks.
fourds is offline
post #2 of 8 (permalink) Old Dec 24th, 08, 05:37 PM
Larry
Re: Alternator Brackets help wanted
try zoops
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
post #3 of 8 (permalink) Old Dec 24th, 08, 05:50 PM
This is the company to deal with in regards to brackets and pulleys.....
http://www.marchperf.com/
I have their serpentine pulleys and related engine brackets on my '69.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #4 of 8 (permalink) Old Dec 24th, 08, 07:33 PM
Allen Grove is another to try, they do a lot of variety.
69 with a drivers side alt is odd. Long or short water pump?
post #5 of 8 (permalink) Old Dec 25th, 08, 12:51 PM
Jim asks that b/c a '69 should have a pass side mounted Alt. and a long w/p.
If yours is this way, then I would look into the serpentine belt accessory drive off an old 4.3 L Astro Van in a Bone Yard and go.
pdq67
post #6 of 8 (permalink) Old Dec 26th, 08, 07:29 AM Thread Starter
Ruben
Thanks for all the replys.I have tried March Performance Pulleys and they said I needed the complete set. i have their pulleys on the crank,power steering,water pump and the alternator. The problem is I did not get the A/C kit. The system was bought at a swap meet new in the box. As for the alt. on the drivers side yes this is not common but I bought a Classic Air A/C system and the compressor is on the passanger side. Also I am using a long water pump due to that is what the A/C system called for.So i am still tring to complete this wild puzzle.I may have to start over and just go with the V belt pulleys?This site has been a great help for me I would like to say THANKS for all the HELP.
fourds is offline
post #7 of 8 (permalink) Old Dec 26th, 08, 07:57 AM
You might look into an '88-'94-95(before Vortec) GMC/Chev truck set-up.
A plate bolts onto the front of the block, accessories attach to it and a reverse rotation long water pump is needed.
You could use the rotary A/C compressor to come with it.
post #8 of 8 (permalink) Old Dec 26th, 08, 09:11 AM
Ted
I have the March mid-mount serpentine belt conversion kit. The alt. will be on the passenger side. The a/c compresser will be below that. It is for a lwp setup. It uses one serp. belt and one v-belt for the pwr steering. I have to decide VA or Classic AA a/c.
tgifford5 is offline
