Torque for BB Oil Filter Insert? - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 26th, 08, 09:35 AM Thread Starter
JB
I'm finishing up putting my 427 together and need to install the threaded piece into the oil filter housing (uses 1 bolt). Can anyone tell me the proper torque for that 1 bolt?
Thanks!
69RSMAN is offline
post #2 of 6 (permalink) Old Dec 26th, 08, 12:52 PM
Re: Torque for BB Oil Filter Insert?
Thanks!
Hi, Not sure what 1 bolt housing you are refering to, but the oil filter adaptor is different for early 1965-1967 396/427 engines, it uses (2)-1/4" UNC bolts to retain it, and these engines used a can type oil filter. later blocks 1968 up have (2) 5/16" UNC bolts to retain the spin on oil filter adaptor.
If you post some more info, I will try to help.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #3 of 6 (permalink) Old Dec 26th, 08, 12:59 PM Thread Starter
JB
It's a 69, and does have the 2 bolts your talking about for the filter spinner - threaded piece.
69RSMAN is offline
post #4 of 6 (permalink) Old Dec 26th, 08, 01:17 PM
16-18 ft lbs.
rszmjt is offline
post #5 of 6 (permalink) Old Dec 26th, 08, 01:30 PM Thread Starter
JB
Thanks!!!!!!!!
I believe there is no gasket that goes on the adapter and I think there should be no thread lock on the bolts?
Does this sound correct?
69RSMAN is offline
post #6 of 6 (permalink) Old Dec 26th, 08, 01:49 PM
Thanks!!!!!!!!
Your Welcome and Yes that is correct.
rszmjt is offline
