dipstick tube - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 28th, 08, 09:33 PM Thread Starter
seeburg220's Avatar
dipstick tube
The internal dipstick tube extension, that's inside of the crankcase: what keeps it from sliding out of the engine block? I'm trying to re-install mine, and it seems like it will just fall out.
1969 / 350 / TH350 / 3.73 posi / driver
seeburg220 is offline
post #2 of 12 (permalink) Old Dec 28th, 08, 09:39 PM
"Tri-Tip"
Gary L's Avatar
Re: dipstick tube
It should be flanged at the top.
Gary L is offline
post #3 of 12 (permalink) Old Dec 28th, 08, 09:44 PM Thread Starter
seeburg220's Avatar
Re: dipstick tube
I'm suffering from memory loss - does the tube then drop into the block from the outside, with the flange staying seated at the top outside of the block? That would make sense, but I didn't think the dipstick tube would fit into it?
post #4 of 12 (permalink) Old Dec 28th, 08, 09:50 PM
Re: dipstick tube
a little bit of jb weld at the end will help.
life4christt is offline
post #5 of 12 (permalink) Old Dec 28th, 08, 10:15 PM
Ron
Re: dipstick tube
Once you got it in there, I use a Spark Plug Rubber End off an Ignition Wire and slip it over the Tube to Pan Joint. This will ensure no Oil Leaks out. You might have to slide the Rubber Collar on the tube first, if your tube has a top bracket ;o)
This was my 70 1/2 Z28
Z15CAM is offline
post #6 of 12 (permalink) Old Dec 28th, 08, 10:37 PM
Re: dipstick tube
The block is counterbored approx. 3/4" for the internal tube and the outer tube is pressed into the block butting up against the internal tube. At least on a SB.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #7 of 12 (permalink) Old Dec 29th, 08, 10:17 AM
Re: dipstick tube
I used high temp silicone on the end of mine.
deerhunter is offline
post #8 of 12 (permalink) Old Dec 30th, 08, 04:19 PM
Bill
Re: dipstick tube
I know a lot of original SB chevy dipsticks and also aftermarket versions have a bracket that's typically welded or attached to the tube that goes into the block. The bracket then has a mounting location such as a header bolt or valve cover bolt that keeps it from ever sliding up. Not sure what was stock on 1st gens but that configuration is what I have on my original vette and my after-market ZZ383 in the Camaro.
68RS-SS is offline
post #9 of 12 (permalink) Old Dec 30th, 08, 05:10 PM Thread Starter
seeburg220's Avatar
Re: dipstick tube
I'm not talking about the external dipstick tube; I'm talking about the extension tube that's inside of the block/crankcase. It slides up into the block hole to meet the end of the external dipstick tube. The other end protrudes into the crankcase below the crankshaft and acts as a guide for the dipstick.
If someone has a picture of this, that would be great.
post #10 of 12 (permalink) Old Dec 30th, 08, 05:24 PM
Re: dipstick tube
Yea, But it goes in from the top, I should have explained that in my post. The block is counterbored as I posted and the lower tube goes in first (from the top side of the engine deck), bottoming against the machined step, then the upper tube is pressed in.
Hope this Helps. Mike.
rszmjt is offline
post #11 of 12 (permalink) Old Dec 30th, 08, 05:51 PM
Chad
67 Plum's Avatar
Re: dipstick tube
Here is a pic of it http://www.ecklers.com/product.asp?p...77&dept_id=153 As Mike said it goes in from the top and the dipstick tube goes in on top of it.
67 Plum is offline
post #12 of 12 (permalink) Old Dec 30th, 08, 08:06 PM Thread Starter
seeburg220's Avatar
Re: dipstick tube
click! The light just came on! Thanks for the explanation - that makes sense now. I usually take digital pics when I'm getting ready to tear something down, but didn't this time. Cheers
