Racing vs OEM Spark Plugs - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 31st, 08, 06:52 AM Thread Starter
DeAngelo
I noticed that racing plugs have a smaller strap and less insulation, thus making a colder plug. Why is the strap smaller? How does that affect use? What difference does it make if I get an OEM plug vs racing plug within the same heat range? Thanks!
Deangelo66 is offline
post #2 of 5 (permalink) Old Dec 31st, 08, 10:32 AM
The Driver
Re: Racing vs OEM Spark Plugs
Your compression ratio will determine the heat range of the plug. I run AC R43TS in my 454 with 11.25:1 compression. If it was around 9.5 to 10.25 I would run a "4" heat range (AC R44TS) and if it was 8.0 to around 9.5 I would run a "5" heat range (AC R45TS). Don't know anything about "racing" plugs, other than there are a lot of gimmick spark plugs being produced.
Wooderson is offline
post #3 of 5 (permalink) Old Dec 31st, 08, 10:58 AM
DjD
DjD's Avatar
Higher compression is indicative of more HP so the more compression the colder the plug. There are more ways to make power than raising compression so as a rule of thumb go 1 range colder than the factory recommendation for every 75 hp increase over the stock engine. The plugs insulator wicks heat from the chamber, a colder plug wicks more heat and a hotter plug wicks less.
Here's a great but of spark plug tech, page 2 gets into heat ranges...
http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml
...Dennis
DjD is offline
post #4 of 5 (permalink) Old Dec 31st, 08, 11:14 AM Thread Starter
DeAngelo
Thx! Long story but here is the Reader's Digest version: I have a 383 with 9 1/2 to 1 compression and Holley aluminum heads that had Autolite race plugs. It worked fine. A mechanic told me to go to a warmer plug and it seemed to work but now it pings at above 3500 RPM or so when I get on it. I have regular Autolite 3923's in it now with the timing only at 11 degrees. Total is about 32 degrees with an HEI MSD distributor. I may go back to the racing plugs coz I don't worry about fouling because I don't "baby" it. Or I may go to the 3922's since they are one step colder. I hate to go through the hassle of changing the plugs if I have to do it again if the 3922's don't work. I would then go to the racing plugs. maybe I should just go straight to the racing plugs and skip going to the one step colder 3922's. Thx! DeAngelo
post #5 of 5 (permalink) Old Jan 2nd, 09, 09:09 AM Thread Starter
DeAngelo
I received the new motor with Autolite AR3933 plugs. I am going back to those plugs. Thx. D
