question??? - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 1st, 09, 09:06 PM Thread Starter
question???
my 307 was running fairly rough [i.e. backfiring,sputtering,bad throttle response].i left and when i came back and tried to start it it wouldnt fire.it's spinning over but no fire.the points are making contact and appear to be sparking.what could it be???
1969nova is offline
post #2 of 12 (permalink) Old Jan 1st, 09, 09:26 PM
Alan
Re: question???
Need more info. Did you do anything to the car or did it suddenly manifest? Check for spark at the plugs, gas in carb. Possibly electrical, check connections at coil.
alan
alanrw is offline
post #3 of 12 (permalink) Old Jan 1st, 09, 09:33 PM
Bruce
Re: question???
Could possibly be the condensor or timing chain
69 Z28 RS Lemans blue / blue interior 19000 miles
68 Camaro Racecar, ex Checkmate Modified Production car. Still running smallblock/stick.
killintime is offline
post #4 of 12 (permalink) Old Jan 1st, 09, 09:34 PM
Jeff
Re: question???
Condensation inside the cap?
tilley88 is offline
post #5 of 12 (permalink) Old Jan 1st, 09, 09:48 PM Thread Starter
Re: question???
I replaced the condensor and it still won't fire.it had two condensors.I don't know why.I tried it with 1and2 and it still won't fire.I did nothing to the car before this happened.
1969nova is offline
post #6 of 12 (permalink) Old Jan 1st, 09, 09:48 PM Thread Starter
Re: question???
new cap also.
1969nova is offline
post #7 of 12 (permalink) Old Jan 2nd, 09, 05:21 AM
BILL
SPARKY69's Avatar
Re: question???
Do you have spark at the plugs ?
SPARKY69 is offline
post #8 of 12 (permalink) Old Jan 2nd, 09, 07:18 AM
Harry
dawg's Avatar
Re: question???
Points need regapping and cleaning im betting
434 stroker
US Navy retired
dawg is offline
post #9 of 12 (permalink) Old Jan 2nd, 09, 09:55 AM
Re: question???
Check for spark at the plugs and make sure it isn't fuel related. It could be a plugged fuel filter. If you are getting spark and fuel it could be a timing issue.
deerhunter is offline
post #10 of 12 (permalink) Old Jan 2nd, 09, 11:08 AM Thread Starter
Re: question???
im getting spark to the plugs but i dont know if it is enough???its getting plentyu of fuel.
1969nova is offline
post #11 of 12 (permalink) Old Jan 2nd, 09, 11:23 AM
BILL
SPARKY69's Avatar
Re: question???
blue or yellow what color, weak or strong ,whats the intensity of it ,did you flood the motor? pull a plug and see if its flooded..
SPARKY69 is offline
post #12 of 12 (permalink) Old Jan 2nd, 09, 11:40 AM Thread Starter
Re: question???
it is bluish-yellow.its not real strong.ill pull a plug and see if it is flooded but, i dont think it is.
1969nova is offline
