Camaro 327 - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 4th, 09, 03:40 PM Thread Starter
Camaro 327
Hello there guys i was told thats a 327 small block will go into my 98 camaro without many changes. transmission and drive shaft all i would have to change is the fuel lines...can u guys give me some insight on this?
Acewille is offline
post #2 of 12 (permalink) Old Jan 4th, 09, 04:02 PM
Re: Camaro 327
......I don't know if those V6 frame mounts are gonna work with that 327??
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #3 of 12 (permalink) Old Jan 4th, 09, 06:32 PM
Talking Re: Camaro 327
You are going to have to change ALOT more than fuel lines. I believe 98 was the first year of the LS1. That engine is totally different, and everything is computer controlled. The 327 stopped being made in 1969, and never had a computer. If the car was a V-6 even the transmission must be changed. Someone is feeding you some BS.
TJS69 is offline
post #4 of 12 (permalink) Old Jan 4th, 09, 07:32 PM
Re: Camaro 327
.......^^^^^^ I agree!!!!!
Turbo 400
post #5 of 12 (permalink) Old Jan 5th, 09, 01:41 AM
T
Re: Camaro 327
Well, what engine is in your Camaro now? I think the newer 5.3L LS-series engine should be "close" to drop-in for an LS1, but technically, it is a 325, not a 327, plus, it's a crappier engine than the 5.7L LS1.
I'd think anything other than that swap would be a lot of work and not worth the energy. Probably a lot easier with 93-97 F-body which used the LT1, but still not worth the effort (and I LIKE the 327)....
TMessick is offline
post #6 of 12 (permalink) Old Jan 5th, 09, 05:09 AM
BILL
SPARKY69's Avatar
Re: Camaro 327
sub frame has to be pulled out to drop an old style motor in and everything is diffrerent..trans, fuel lines, mounts...
SPARKY69 is offline
post #7 of 12 (permalink) Old Jan 5th, 09, 04:30 PM
Re: Camaro 327
Aren't these new engines like 325" and 347"??
pdq67
post #8 of 12 (permalink) Old Jan 5th, 09, 08:46 PM Thread Starter
Re: Camaro 327
i have a v6 3.8 well the shops told me that the gaskets are blown n they keep saying get a rebuild engine or a new engine...but the engine is rebuilt already with 60k miles on it...exhaust was blowing out of the radiator also he said the oil pan was over full..it blows out blue smoke no heat..its over heating when ran too long he also told me it ran better with new spark plugs n it thats why im wondering why do they keep telling me the engine is no good...why cant i just replace the gaskets? its not knocking either.
Acewille is offline
post #9 of 12 (permalink) Old Jan 5th, 09, 09:54 PM
Smile Re: Camaro 327
V-6's are notorius for blowing head or intake gaskets. He has no idea if your main bearings etc. are going to go, because of water in the oil. If I was in his position, I would say the same thing. If he fixed the gaskets, which will cost you a bunch, and then the main bearings went out in a week, How happy would you be ? Now he has to rebuild it, at who's cost ? YOURS... aren't you going to be po'd. Put a new GM crate engine (v-6) in it, and be done with it.
TJS69 is offline
post #10 of 12 (permalink) Old Jan 7th, 09, 11:21 AM Thread Starter
Re: Camaro 327
yea im lookin for a new 1 but wat website
Acewille is offline
post #11 of 12 (permalink) Old Jan 7th, 09, 12:19 PM
Re: Camaro 327
Just go down to your local napa...
post #12 of 12 (permalink) Old Jan 7th, 09, 12:25 PM
BILL
SPARKY69's Avatar
Re: Camaro 327
or advance auto or auto zone...
SPARKY69 is offline
