Vortec head questions - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 6th, 09, 09:28 AM Thread Starter
seeburg220's Avatar
I just got my Vortec heads from Summit today
Question: can I use the headbolts from the old Gen.1 heads, or do I need new bolts to fit?
Also, what pushrod length do I need: hyd. cam, not too big, Comp Cams roller tip rockers (self aligning)? Thanks.
ps - I'm really disappointed to find out the heads are cast in Mexico and my Weiand Stealth intake is made in China ! $%$!&*
They don't tell you that in the catalog. Next time, I'll buy an Edelbrock manifold.
1969 / 350 / TH350 / 3.73 posi / driver
seeburg220 is offline
post #2 of 8 (permalink) Old Jan 6th, 09, 05:32 PM
Patrick
Re: Vortec head questions
Stock head bolts will work fine. Also stock length pushrods should work BUT you should ALWAYS check first.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #3 of 8 (permalink) Old Jan 7th, 09, 11:09 AM
other than the intake manifold, self guided rocker arms, and center bolt valve covers the vortecs are a direct swap with older heads.. you will also need a water temp sending unit with 3/8 npt threads instead of the 1/2" npt used in the older stuff.
you don't plan sincerity.
novaderrik is offline
post #4 of 8 (permalink) Old Jan 7th, 09, 03:58 PM Thread Starter
seeburg220's Avatar
Thanks for the replies. I hadn't thought about the water temp unit size. I've decide to return the chinese intake and buy an Edelbrock.
Oh, what type/size spark plugs should I be using? I'm using a stock HEI distrbutor. Thanks
post #5 of 8 (permalink) Old Feb 22nd, 09, 11:07 PM
I feel your pain on that weiand intake. Had to return my #8151 stealth intake that I whated to use w/ some 062 vortec's I'm rebuilding. Workmanship and machining was really bad. I'm going back to edelbrock, new or used.
TheOrange77 is offline
post #6 of 8 (permalink) Old Feb 23rd, 09, 01:11 AM
spark plugs- AC Delco R44LTSM or R45LTSM. you can also get "LTS" plugs without the "M"- i forget what the "M" means. i think it is a more projected tip or something..
they are a 3/4" reach tapered seat plug with a 5/8" hex.
post #7 of 8 (permalink) Old Feb 23rd, 09, 03:22 PM
The M is for Marine
BPOS is offline
post #8 of 8 (permalink) Old Feb 23rd, 09, 04:36 PM
Patrick
Originally Posted by BPOS View Post
The M is for Marine
Would there be a benefit to using the marine plugs? What would be the difference like which one is better?
383 IS SOLD!
Building a 489BBC
