Will a 7 qt oil pan fit into a 68 camaro - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 6th, 09, 03:29 PM Thread Starter
Norman
i am building a 383 stroker for my camaro and wanted to know if a 7qt oil pan will fit in the car without a problem? what do you guys think about 7 quart oil pans in general?..any info would be great. Jay
camaroboyy is offline
post #2 of 12 (permalink) Old Jan 6th, 09, 03:35 PM
Re: Will a 7 qt oil pan fit into a 68 camaro
What kind of 7 quart pan? Like this?
http://www.jegs.com/i/Moroso/710/20190/10002/-1
Yes this will fit.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #3 of 12 (permalink) Old Jan 6th, 09, 03:37 PM
Larry
7 qt pans fit no problem. The additional oil is a good thing to have @ high rpm so you don't starve the lower end for oil when a majority of the oil gets pumped to the top end.
Sometimes it's better to let someone think your an idiot, than to open your mouth and remove all doubt...
ls427ss is offline
post #4 of 12 (permalink) Old Jan 6th, 09, 03:44 PM Thread Starter
Norman
yes rszmjt just like that. but this one http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
post #5 of 12 (permalink) Old Jan 6th, 09, 05:13 PM
What I used http://www.champpans.com/index.cfm?e...ctdetail&id=83
What I did like most about this pan was the removable windge tray, mounted in the pan. This makes it easier to R&R with motor in car, without pan hanging on windge tray studs .
Use the one piece pan gasket . Save yourself some trouble.
TC # 349
zdld17 is offline
post #6 of 12 (permalink) Old Jan 6th, 09, 05:53 PM
Jay, The ebay pan Looks OK, But be aware that sometimes cheap pans dont fit the block that great, they are usually a little warped from welding and I have found lots of slag inside the pan, and the bolt holes sometimes need to be drilled 1 size over. You sometimes have to rolox disc out the welding slag in the pan and then steam the heck out of it.
It is very hard to get this style of pan off in the car especially if you have headers.
Pretty reasonable price. Make sure you tig weld the pickup into the pump body. JMO.
rszmjt is offline
post #7 of 12 (permalink) Old Jan 6th, 09, 06:17 PM
I also use the champ pan. It's a great peice, American made in Wisconsin, too. Rather than ordering on the web, call them. Make sure you get the right pickup for the pump you will use. I used the 10555, the so-called "big block pump for a small block." and it took 2 tries to get the right pickup.
Their pictures do not do it justice. These are 100% fabricated from new heavy gauge steel. They do not look like those others which look like someone sawed the bottom off a (chinese) stock pan and welded a sump onto it.
post #8 of 12 (permalink) Old Jan 6th, 09, 06:32 PM
The pan you reference says "will not fit rear steer chevelle" I dont remember rear steer
Chevells, but old Camaros are. Check carefully.
john68 is offline
post #9 of 12 (permalink) Old Jan 6th, 09, 08:15 PM
call them. the online catalog is a lil sketchy. The guy who answers the phone knows what fits.
post #10 of 12 (permalink) Old Jan 6th, 09, 08:54 PM Thread Starter
Norman
thanks for your help guys.
post #11 of 12 (permalink) Old Jan 7th, 09, 12:21 AM
Carl
CV Products CV1080LTRR. Great fitting pan that will work well for street, strip, and road course. It's made by Champ.
CarlC is offline
post #12 of 12 (permalink) Old Jan 7th, 09, 03:58 AM
Regardless of brand, I suggest to get the pan having the drain plug on the side rather than the rear. No interference.
Any pan not lower than 8 1/4 inches will be protected by the crossmember.
Be sure the headers, at least the driver side, is on first, or install the header first hanging it by the hood hinge, or you will have to lift up the engine and swing it over to the pass side to install the drvr header. Some side expanded pans give limited room for installing headers. Those pans the same block width don't have too much of a problem.
