JB Weld on intake - Team Camaro Tech
post #1 of 17 (permalink) Old Jan 8th, 09, 07:08 AM Thread Starter
JB Weld on intake
So i bought a Edelbrock RPM Airgap Manifold off craigslist. Got a good deal on it so i thought. It arrived and it looks like someone had the manifold drilled for NOS injectors. There are holes in all the runners. It has JB weld in the holes and smooted out inside and then ground smooth on the top. I feel scammed and the seller is willing to make this right with me. Is this safe to run?
_PuNiShEr_ is offline
post #2 of 17 (permalink) Old Jan 8th, 09, 07:12 AM
Re: JB Weld on intake
I'd return it if the seller is willing to refund you. It might not vacuum leak, but I wouldn't want to trust it.
Eric
Eric Kammerer is offline
post #3 of 17 (permalink) Old Jan 8th, 09, 07:17 AM
BILL
SPARKY69's Avatar
i would definatly return it...sounds like problems down the road....
SPARKY69 is offline
post #4 of 17 (permalink) Old Jan 8th, 09, 07:55 AM
jason
shouldn't be a problem.
68z28sd is offline
post #5 of 17 (permalink) Old Jan 8th, 09, 07:59 AM Thread Starter
Thanks guys. What would you think it would cost to have someone fix it correctly by welding them shut?
post #6 of 17 (permalink) Old Jan 8th, 09, 08:43 AM
Mickey
Moonpie's Avatar
Last aluminum welding I had done was 75.00. Took him 5 minutes. had to get that hour of labor tho. I swear by JB Weld but would return it too if postage wouldn't make it too expensive. If you get it welded take it to a regular welding shop and not a speciality shop like I did.
Moonpie is offline
post #7 of 17 (permalink) Old Jan 8th, 09, 08:49 AM Thread Starter
Im a draftsman at a machine shop we do welding i just dont know if we do aluminum. Surly someone does. Maybe i can get a favor done. Now how do i remove the JB weld is the question.
post #8 of 17 (permalink) Old Jan 8th, 09, 08:52 AM
Chad
67 Plum's Avatar
Drill it tap the holes and install pipe plugs.
67 Plum is offline
post #9 of 17 (permalink) Old Jan 8th, 09, 08:55 AM Thread Starter
Sometimes I over look the obvious... thanks! just need a way to remove the jb weld so that it doesnt get sucked into the cylinder. When i say the coated the inside of the runners they coated them probably about a 1 inch square of JB weld
post #10 of 17 (permalink) Old Jan 8th, 09, 09:08 AM
Chad
67 Plum's Avatar
Try heating it with a small propane torch.It should scrape off after being heated.
67 Plum is offline
post #11 of 17 (permalink) Old Jan 8th, 09, 09:32 AM
Bill
Send a message via Yahoo to IDS_Bill
I had a guy grinding pistons for a motorcycle I was racing and ground through the relief for the valve into the ring channel. His solution was to fill it with JB Weld and smooth it. It actually worked although I would never try it again. I was young and broke in college at the time so I went with it...
67 Yenko Tribute - 427/4SPD/Bolero Red
2010 2SS/RS Camaro - Victory Red with White Rally Stripes
IDS_Bill is offline
post #12 of 17 (permalink) Old Jan 8th, 09, 10:13 AM
JB Weld is not an issue. However, appling heat to remove the JB Weld and then later, TIG weld the holes to start over, reface the surfaces mating to the heads for straightness, only need a few thousands removed, say 0.003" min.
post #13 of 17 (permalink) Old Jan 8th, 09, 10:59 AM
Chad
67 Plum's Avatar
Not talking about an acetylene torch just one of the little hand held ones.Not enough heat to hurt anything.
67 Plum is offline
post #14 of 17 (permalink) Old Jan 8th, 09, 11:30 AM
Ron
I would drill out the JB-Weld, tap a thread and install Brass Allen Plugs with Lock-Tite. It would look good and if you ever decided on NOS Injection by all means. The RPM Air Gap comes with Bosses for Fuel or NOS Injectors;o)
You could also use a larger Brass Boss Fitting that protruded with a Plug that would accept NOS Nozzles.
Heating the area with a Propane Torch an use a small wire disc on a drill would ensure you got rid of all the JB-Weld.
Sorry I could not finish the post as my ISP keeps dropping
NOTE: The RPM AIR GAP comes with Injector Bosses. If they are set up to be active I would say it is a Plus.
Clean the intake with lacquer thinner, Sand Bast lightly - Shoot 3 coats of Epoxy Ferris Epoxy Primer and a few coats of Ceramic Acrylic Enamel and bake at 200 F for 20 minutes in your kitchen oven. You will have a finish that is as good as Edelbrocks Endura Shine and looks Stock.
PS: I got rid of the 2 Valve Cover Breather for a properly working PCV System.
As I say the Brass Allen Plugs would look GREAT! ;o)
Like my fabbed Throttle and Gas line brackets - Simple 3/4 x 3/16" flat stock and yes that's a wrench supporting the throttle return spring.
This was my 70 1/2 Z28
Z15CAM is offline
post #15 of 17 (permalink) Old Jan 8th, 09, 11:30 AM
Agree, Butane pencil torch would work. MAPP gas would work also.
