Leaking Thermostate Gasket - Team Camaro Tech
post #1 of 38 (permalink) Old Jan 8th, 09, 02:12 PM Thread Starter
Ron
Other then obvious casting damage which has to be repaired, I've found, over the years, that a leather gasket cut from an old glove works the best.
I've posted this because I've seen lots of members asking for a FIX !!!!!
This was my 70 1/2 Z28
Z15CAM is offline
post #2 of 38 (permalink) Old Jan 8th, 09, 02:14 PM
Skip
Skeeter55's Avatar
Re: Leaking Thermostate Gasket
Ron sometimes we cant beat old technoly....
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 38 (permalink) Old Jan 8th, 09, 02:17 PM
BILL
SPARKY69's Avatar
never heard that before.. cool
SPARKY69 is offline
post #4 of 38 (permalink) Old Jan 8th, 09, 02:17 PM Thread Starter
Ron
You want to discuss this with "OLD" Indian Shellac pdq67 - LOL
Z15CAM is offline
post #5 of 38 (permalink) Old Jan 8th, 09, 02:26 PM
Skip
Skeeter55's Avatar
He Ron: Our paint sprayers use a set of leather packings, nylon plastic and rubber to help seal our paint rigs.
post #6 of 38 (permalink) Old Jan 8th, 09, 02:34 PM
BILL
SPARKY69's Avatar
.99 felpro gasket works great for me........
SPARKY69 is offline
post #7 of 38 (permalink) Old Jan 8th, 09, 03:08 PM Thread Starter
Ron
Fel-Pro is Not as good as a Leather Gasket - Period - Been there did that!
Z15CAM is offline
post #8 of 38 (permalink) Old Jan 8th, 09, 03:13 PM
Dale
Send a message via AIM to Dale8346
Ron,
I too will stick to the .99 Felpro Gasket.
Been using them for 35 years, and the only 2 that ever leaked on me where because I screwed them up. 2 our of 1000 are pretty good odds to me. Thanks for the info though.
Dale8346 is offline
post #9 of 38 (permalink) Old Jan 8th, 09, 03:19 PM Thread Starter
Ron
Believe it - It's FACT - Old Tech! - Cut out a Leather Thermostat Gasket from an Old Leather Glove.
And Torque the Bolts to say 25 to 30 PSI = NO PROBLEM-TOW ;o)
Z15CAM is offline
post #10 of 38 (permalink) Old Jan 8th, 09, 09:11 PM
Dale
Ron,
I believe you. And if I am ever stuck on a desert Island where I don't need my leather gloves I will use your technique. Or if I have no parts store available one day, I will try your technique.
I can also wear gloves on my feet, but I am use to sox.
Dale8346 is offline
post #11 of 38 (permalink) Old Jan 8th, 09, 09:49 PM
There was a story floating around the town I grew up in about a guy that had an old vehicle, probably 40's or early 50's, that had a rod knocking. He dropped the pan, remove the babbit bearing, cut a chunk the right length out of an old belt, put the thing back together and it ran quite enough he could trade it in.
deerhunter is offline
post #12 of 38 (permalink) Old Jan 9th, 09, 05:14 AM
BILL
SPARKY69's Avatar
WOW, IVE NEVER HAD A .99 FELPRO GASKET GO BAD...ITS TO WARM DOWN HERE, NOBODY WEARS GLOVES!!
SPARKY69 is offline
post #13 of 38 (permalink) Old Jan 9th, 09, 02:03 PM
gotta love those small town stories..
as for the gasket thing, the Fel PRo gasket hanging on the wall at the parts store has always worked for me. the only time i've ever had a problem was when i was trying to get an aftermarket chrome water outlet to seal- my fix was to put a stock outlet on it.
you don't plan sincerity.
novaderrik is offline
post #14 of 38 (permalink) Old Jan 9th, 09, 08:12 PM
...........you're in the NC back woods.....30 miles from the nearest town that does not have a parts store with a 99 cent gasket...it's gettin' dark....in the floor board is a pair of leather gloves...... 2 guys and a blind banjo playin' boy show up in a pick up truck.......you gonna make a gasket outta that leather glove?????????...............
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #15 of 38 (permalink) Old Jan 9th, 09, 08:36 PM
Or put a piece of sandpaper on a hard and flat surface and make the thing flat.
