Factory Windage Tray - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 8th, 09, 06:52 PM Thread Starter
Was a factory windage tray installed in 396/375 or COPO Camaro's?
Found one on my 435/427 engine and was not sure if Corvette only equipment.
copo9560 is offline
post #2 of 6 (permalink) Old Jan 8th, 09, 08:28 PM
Re: Factory Windage Tray
Never installed in Camaro/Chevelle/Nova etc 396/375 or iron motor COPO,s but ZL1 did get them apparently, although it might have been a factory over the counter part.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #3 of 6 (permalink) Old Jan 8th, 09, 09:55 PM
AJ
Didn't most stock oil pans (even sbc low power) get some kind of screen mesh thing though?
Could this be what you are seeing?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #4 of 6 (permalink) Old Jan 9th, 09, 06:14 AM
Ron
Is this Main Bolt Mounted or a Pan Item?
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 6 (permalink) Old Jan 9th, 09, 05:52 PM Thread Starter
The tray was mounted off the center cap main cap bolts toward the rear. Had interesting bolts that had extended studs included - needed a deep well socket to remove the main bolts. This was installed on an iron 512 block - was curious if it was used in any other applications. I no longer have the tray but the odd fasteners are still holding mains in place.
copo9560 is offline
post #6 of 6 (permalink) Old Jan 9th, 09, 06:26 PM
Fred
What? Never installed in L78's? Huh? I've still got my original. Bolts and all. I moved them to the L88. That was 33 years ago. Could I be losing it??? One of the things the L78 was famous for was the windage tray. I remember it as always being standard equipment.
Just your basic beer-getter:
128.79mph 1.428 60'
Fred Ficarra is offline
