I found this on the chevelle site great read. check it out.
With respect to flat tappet cam protection,not roller cams.
The newer CJ version of shell's rotella 15w-40 is no longer any good for any kind of perf flat tappet cam protection,this newer version has too low of zddp lvl for safeuse with perf flat tappet cam's running higher sprng rates.
Here is the list of the latest conventional oils & oil additives with good zddp for flat tappet cam protection.
Some flat tappet cam mfgs rec against using syn oil for breakin etc and it also cost 2x-3x more then conven oil too so thats why i have not listed them even though some have god zddp protection pkg's.
(CONVENTIONAL OILS AND OIL ADDITIVES WITH "ZDDP" FOR FLAT TAPPET CAM & LIFTER BREAKIN & ALSO ONGOING PROTECTION POST BREAKIN V4 1/5/09)
A) OIL ADDITIVES BEST SUITED FOR FLAT TAPPET CAM & LIFTER BREAKIN
B) WHERE TO BUY THE BREAKIN ADDITIVES ALONG WITH PT#'S
C) CONVENTIONAL OILS CURRENTLY ON THE MARKET (SOME NEW ) WITH GOOD ZDDP LVLS FOR FLAT TAPPET CAM BREAKIN & ONGOING PROTECTION POST BREAKIN & WHERE TO BUY THEM.
D) OIL ADDITIVES WITH MOSTLY ZDDP THAT'S BEST SUTED FOR ONGOING PROTECTION POST CAM & LIFTER BREAKIN & WHERE TO BUY THEM
NOTE: IN GENERAL/ROUGHLY LOOK FOR A MINIMUM 1200PPM -1400PPM ZDDP/ZINC & PHOSPHORUS FOR FLAT TAPPET CAM PROTECTION ,
STOCK TO MILD PERF CAM'S ARE OK ON THE LOWER END LIKE APPROX 1200PPM -1300PPM AND HOTTER PERF CAMS WITH HIGHER SPRING RATES & MORE AGRESSIVE LOBE DESIGNS ARE ON THE UPPER END LIKE 1350PPM - 1400PPM . EVEN A LITTLE MORE ZDDP LIKE 1500-1600+ZDDP WOULD NOT HURT FOR A REAL HOT CAM EITHER. A FEW PPM ZDDP EITHER WAY/ UP OR DOWN IS NOT AN ISSUE,JUST STAY FARILY CLOSE/WITHIN REASON TO THESE REC AND YOU SHOULD BE OK.
A) OIL ADDITIVES FOR FLAT TAPPET CAM & LIFTER BREAKIN :
GM EOS & CRANES SUPERLUBE ENGINE BREAKIN CONCENTRATE ARE BOTH GREAT FOR FLAT TAPPET CAM/LIFTER BREAKIN & ALSO SHOWED GOOD/HIGH ZDDP LVLS. (BOTH SHOWED APPROX 5,500-6,000PPM ZDDP WHEN TESTED)
NEW ON THE MARKET IS THE " LUCAS ENGINE BREAKIN OIL ADDITIVE TB ZINC PLUS " (5KPPM ZINC W-4.5 QTS OIL PER LUCAS/MFG) . BUT DON'T MISTAKE THE "LUCAS OIL STABILIZER" FOR THE NEW FLAT TAPPET CAM BREAKIN ADDITIVE WHICH IT'S NOT,THERE IS NO ZDDP IN THE LUCAS OIL STABILIZER AT ALL SO I WOULD NOT REC IT FOR FLAT TAPPET CAM BREAKIN AND OR FOR POST CAM BREAKIN PROTECTION EITHER .
I USE CHEVRON'S DELO 15W-40 WITH GM EOS OR THE CRANE LUBE FOR ALL MY FLAT TAPPET CAM BREAKINS. THEY WORK GREAT AND ARE APPROX 3-4X CHEAPER THEN THE JOE GIBS OR BRAD BENN BREAKIN & STD OILS (WHICH ARE GOOD HIGH QUALITY OILS) FOR POST BREAKIN.
B) Listed below are the PT#'s and where to buy GM EOS/CRANE'S SUPERLUBE/LUCAS BREAKIN ADDITIVE TB ZINC PLUS.
GM EOS,is the cheapest from GMPARTSDIRECT online @ approx $12.00 pint + S&H =approx $16.00 It can also be found in Jeg's listed as a cam prelube in catalog and at a gm dealer at the highest cost ($20+) unless you know somebody that can get you the dealer/wholesale price.
GM EOS PART # is - 88862586
Also,Cranes superlube engiine breakin concentrate is just as good or better then GM EOS and can be ordered from Summit with crane's moly paste assembly lube.
In Summit Crane's superlube engine breakin concentrate oil additive is pt # - CRN-99003-1 & the Crane grey moly paste assembly lube is pt # CRN-99002-1
LUCAS PT# 10063
IT'S CALLED: ENGINE BREAK-IN OIL ADDITIVE TB ZINC PLUS
ACCORDING TO LUCAS 16OZ BOTTLE IN 4.5QTS OIL = APPROX 5,000PPM ZINC
HERES THE LINK TO THE MFG SPECS FOR THRE NEW LUCAS OIL ADDITIVE:
http://static.summitracing.com/globa...tve_tbzinc.pdf
HERES THE SUMMIT PT# TO BUY THE LUCAS ADDITIVE : LUC-10063-1
C) HERE ARE MOSTLY CONVENTIONAL OILS(SOME NEW ON MARKET) WITH GOOD ZDDP LVLS FOR FLAT TAPPET CAM PROTECTION.
CHEVRON'S DELO 15W-40 (NEW CJ VERSION1300PPM/OLD CI -1500PPM AS TESTED AND AS PER MFG TOO)/AVAIL IN MOST STORES
SHELLS' ROTELLA ST 30WT (APPROX 1250-1300PPM)/AVAIL IN MOST STORES
NOTE-SHELLS NEWER/POST 1/2007 CJ 15W-40 OIL ONLY HAD APPROX 1050-1100PPM ZDDP WHEN TESTED SO ITS NG IMHO FOR PROTECTING A HIGH PERF FLAT TAPPET CAM BUT THE OLDER/PRE-1/2007 CI RATED ROTELLA 15W-40 WAS OK FOR FLAT TAPPET CAM PROTECTION .
MOTORHEAD'S 15W-40 (1400-1500PPM-PER MFG)/AVAIL ON THEIR SITE
CLASSIC CAR OIL'S 15W-40(1400-1500PPM-PER MFG) /AVAIL ON THEIR SITE
SPECTRO'S NEW 30WT/10W-40/20W-50 (1800PPM- PER MFG)/AVAIL ON THEIR SITE
PENZOILS 25W-50 GT RACING OIL(1400-1500PPM WHEN TESTED,MFG CLAIMS 1600PPM)/AVAIL SUMMIT & JEG'S
VALVOLINES NSL & VR1 RACING OILS(1200-1250PPM WHEN TESTED MFG CLAIMES 1300-1350 PPM) /AVAIL SOME STORES -SUMMIT & JEG'S
ROYAL PURPLE ENGINE BREAK-IN OIL(STATES HAS HIGH ZDDP LVL FOR FLAT TAPPET CAM/LIFTER BREAKIN/ZDDP LVL ?)/AVAIL ON THEIR SITE ,SUMMIT & JEGS
BRAD PENN BREAKIN & RACING OILS ARE VERY EXPENSIVE @ 3X-4X THE COST OF COVENTIONAL OIL & ADV AS HAVING GOOD ZDDP LVLS BUT IT TESTED LOW ON ZDDP WHEN I HAD THIER 20W-50 TESTED 2X SO I KNOW IT WASN'T JUST ONE BAD TEST RESULT AND OR BOTCHED TEST. I CAN'T IN GOOD FAITH REC THE BRAD PENN OIL DUE TO THE 2 BAD/LOW ZDDP TEST RESULTS EVEN THOUGH IT HAS A VERY GOOD REP AMONG THE RACING & ENGINE BUILDING COMMUNITY SO RUNNING THAT OIL IS UP TO YOU. ALSO,I ASKED BRAD PENN OILMFG WHAT THE ZDDP LVLS WERE IN THEIR BREAKIN & STD OILS ANDTHEY WOULD NOT TELL ME THAT INFO.
AS FOR THE JOE GIBS BREAKIN & STD OIL,THATS ALSO 3X-4X MORE $ THEN CONVENTIONAL OIL & ASLO HAS A GOOD REP TOO AMONG RACERS & ENGINE BUILDERS ALIKE BUT UNFORTUNATELY I HAVE NEVER TESTED IT FOR ZDDP SO THERFORE CAN ONLY REC IT ON IT'S REPUATION & NOT IT'S ACTUAL TESTED ZDDP LVL SO RUNNING THAT OIL IS UP TO YOU.
D) These are the latest ZDDP oil additives on the market best suited for ongoing flat tappet cam/lifter protection post breakin that are currently on the market. They are also ok for cam & lifter breakin too when used along with a good quality oil. But i still prefer GM'S EOS & CRANE'S SUPERLUBE ENGINE BREAKIN CONCENTRATE for flat tappet cam & lifter breakin because they are proven products in that application that also have additional additives to aid in cam/lifter breakin that the plain zddp additves don't have :
* ZDDPLUS (TESTED/APPROX 2K Zn & 1,600 P W-6 QTS OIL)/AVAIL ON EBAY & FROM EASTWOOD CATALOG
* CAMSHIELD (TESTED/APPROX 88KPPM - Zn & 75KPPM - P PRIOR TO MIX WITH OIL)/AVAIL ON THEIR WEBSITE
* MOTORHEADS HI "Z" (BOOSTS ZDDP APPROX 50% OR BY 500-600PPM WHEN USED/MIXED WITH AN SM RATED OIL AS INSTRUCTED BY THE MFG) /AVAIL EBAY AND THE MOTORHEAD HI "Z' WEBSITE
1/5/09 V4 SCOTT WHEATON
