Have oil but no pressure - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 10th, 09, 03:11 AM Thread Starter
I just finished putting a 383 motor that I built in my 69’ Camaro. The problem I’m having is no oil pressure and no oil getting to the gauge but I’m getting oil to the valve covers.
Thank You
cordezzy is offline
post #2 of 7 (permalink) Old Jan 10th, 09, 04:41 AM
Re: Have oil but no pressure
My first thought is the galley plug that is under the oil pressure fitting, was it removed?
Are you able to use a priming tool or old dist housing and shaft to prime? The grove on the dist body routes oil to the lifters.
Silly, but are you turning oil pump shaft in the right direction?
TC # 349
zdld17 is offline
post #3 of 7 (permalink) Old Jan 10th, 09, 07:37 AM
Banned
If the plug under the rear main cap is left out it will still have pressure but will bypass the oil filter once its full.
CNC BLOCKS N/E is offline
post #4 of 7 (permalink) Old Jan 10th, 09, 07:45 AM
Thanks Bill.
TC # 349
zdld17 is offline
post #5 of 7 (permalink) Old Jan 10th, 09, 11:27 AM
Banned
Ron
Badbird's Avatar
If you're getting oil to the valvetrain then you do indeed have oil pressure!....Your oil pressure gauge will shoot up once the engine is running!
Badbird is offline
post #6 of 7 (permalink) Old Jan 10th, 09, 11:37 AM
Todd
What? I have always had good oil pressure priming an engine on my gauge.
Vegas69 is offline
post #7 of 7 (permalink) Old Jan 10th, 09, 11:55 AM
Lane
I'm no expert here by no means but I had an oil filter cause this problem for me a couple of years ago.
69' Camaro X44 Base Coupe - 1\4 - 12.79
383 Stroker\700R4\Vigilante\12 Bolt Eaton Posi 3:55
QA1; Hotchkis; Vintage Air; IROC Steering Box
Owned and operated for over 20 years....................
04' CTS-V - Daily Driver -
LS6, Headers, Cam, Corsa exhaust, Electric cutouts.
sixtynine is offline
