RPM Airgap on 454, hood clearence - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 10th, 09, 08:53 PM Thread Starter
Bob
MileHigh69's Avatar
I have a 69 with a 454 and a air cowl hood. Does anyone know if it will fit under the hood?
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #2 of 8 (permalink) Old Jan 10th, 09, 09:05 PM
Skip
Skeeter55's Avatar
Re: RPM Airgap on 454, hood clearence
The 454 will fit fine as long as you have the BB motor mounts stands, also what air cleaner are you going with.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 8 (permalink) Old Jan 10th, 09, 09:08 PM
Todd
I have an air gap, drop body bushings, and 3 inch K+N in a drop base...have a **** hair.
Vegas69 is offline
post #4 of 8 (permalink) Old Jan 10th, 09, 10:02 PM
Ed
BigBlock1969RS's Avatar
Air gap, normal height body bushings, cowl induction hood, tons of space on a 3" air cleaner. I gotta put some modeling clay and see if I can fit a 5" air cleaner on top .
Motor on the stand was sucking the entire air cleaner assembly so hard against the carb that it would start interfering with the throttle assembly if you rev'ed it up, so I think I need a bigger air cleaner.
Ed
BigBlock1969RS is offline
post #5 of 8 (permalink) Old Jan 11th, 09, 10:05 AM
Smile Re: RPM Airgap on 454, hood clearence
Not a bigger air cleaner, but a better air cleaner ! Look at the K&N's etc. You should be able to get by with a 3" tall one.
TJS69 is offline
post #6 of 8 (permalink) Old Jan 11th, 09, 10:09 AM
Skip
Skeeter55's Avatar
Are you thinking on putting a bigger K&N filter in a stock air cleaner like this... This is a 454 block...
post #7 of 8 (permalink) Old Jan 11th, 09, 10:33 AM
Dave C
I would watch the enduroshine the one I bought pealed it may just have been just because it was a new process.
PRO.ST69orange
post #8 of 8 (permalink) Old Jan 11th, 09, 02:00 PM
No, I would just replace the paper element with the same size K&N. They flow much more air than a paper element does. The chart below, shows almost a 25% increase.
Will this fit yours ?
TJS69 is offline
