rocker arms...1/4 more turn??? - Team Camaro Tech
post #1 of 21 (permalink) Old Jan 11th, 09, 11:43 AM Thread Starter
74 LS4 454 hyd lifter Comp 260 HE
I have adjusted my rockers using the TDC 1 / TDC 6 method. After about 100 miles on this totally fresh motor, I have a couple of "tick ticks" that are just agravating.
IF I re-adjust the rockers again....should I be OK with an additional QUARTER or EIGHTH of a turn on the ones that I can still "spin" the pushrods with my fingers ????
I don't want to go too tight and use up the "hyd space" provided with the lifters.....but I dont want to listen to the tick tick tick either.
Thanks for any help here ...
74LS454 is offline
post #2 of 21 (permalink) Old Jan 11th, 09, 12:33 PM
Re: rocker arms...1/4 more turn???
Normal adjustment is 1 full turn from initial contact. However, a performance adjustment was 1/4-1/2 turn to prevent pump-up at higher rpms.
Usually, the locknuts are on the same thread of all studs if they are at the same height for a fast visual reference, at least on SBC's, 3 threads would be showing atop the adjusting nut if using stack crimp nuts.
Sometimes, aftermarket lifters have alot of clearance between the inner body and outer body or the check ball isn't as round as it should be or the seat for the ball isn't a mirror finish for good seating. General fix is to replace the lifter(s). The faulty lifters will be the ones with a sunken inner body, not up against the snap ring, sunk about 1/8 inch.
post #3 of 21 (permalink) Old Jan 11th, 09, 12:39 PM
AJ
Are you 100% sure it's not an exhaust leak?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #4 of 21 (permalink) Old Jan 11th, 09, 01:09 PM
pop off one valve cover, start the motor, and loosen each rocker arm until it just starts to clatter and tighten it back up until it just stops clattering.
after all 8 on that side are done, shut off the motor and turn them all an additional 1/2 turn.
put that valve cover back on, take off the other one, and repeat the procedure.
if your locknuts are good, then that should be the last time you'll ever have to mess with them.
you don't plan sincerity.
novaderrik is offline
post #5 of 21 (permalink) Old Jan 11th, 09, 02:00 PM
Jason
jhorn's Avatar
I have done this similar procedure, except with motor running I loosen rocker until it clatters, tighten until it just stops then 1/4 turn more and you are done. you must be quick or the oil will overflow the head onto the exhaust.
Jason
jhorn is offline
post #6 of 21 (permalink) Old Jan 11th, 09, 02:39 PM
The exhaust manifolds, the inner fenders, the outer fenders, upper control arms, frame rails, your arms, the driveway, and anywhere else you don't want it.
post #7 of 21 (permalink) Old Jan 11th, 09, 04:50 PM
Jason
jhorn's Avatar
my guess is you have done it this way before
Jason
jhorn is offline
post #8 of 21 (permalink) Old Jan 11th, 09, 05:52 PM
Todd
Doubt I try it on mine...even though it works. Not much for making a mess of my headers and everything else in sight.
Vegas69 is offline
post #9 of 21 (permalink) Old Jan 11th, 09, 05:58 PM
DjD
DjD's Avatar
Factory installed hyd cams typically call for 1 full turn. The aftermarket manufactures have their own spec's. Comp hyd cams call for 1/2 turn...
As an experiment I adjusted my comps 1 full turn and the engine ran fine but when I reset them to 1/2 turn I picked up 2" of vacuum at idle...
...Dennis
DjD is offline
post #10 of 21 (permalink) Old Jan 11th, 09, 06:32 PM
I can do mine running wihout losing a drop. I don't get a lot of oil up thruogh the morel hydraulic lifters, and the valve cover rail on my afr heads is high enough that the oil won't overflow like a stock head.
Still, I always roll up a towel and pull it between the head, the header, and the plug wires, and another on the inner fender.
post #11 of 21 (permalink) Old Jan 12th, 09, 05:06 AM
Thanks, Dennis, for the refresh - correct - OEM is 1 turn.
Yes, I did live valve adjusting ONCE - then I did as JimM, towels everywhere and the lowest idle rpm I could obtain.
post #12 of 21 (permalink) Old Jan 12th, 09, 05:31 AM
NHBandit's Avatar
Any self respecting Chevy "car guy" has a couple of old junk valve covers with the top cut off just for doing this hanging on the wall of his shop...
NHBandit is offline
post #13 of 21 (permalink) Old Jan 12th, 09, 07:19 AM
Of course........
post #14 of 21 (permalink) Old Jan 12th, 09, 03:52 PM
john
wagonman's Avatar
this is a very good question!
before adjusting anything,determine where the moise is coming from!
using a piece od vacc tubing..listen along the ex-manifold and inside the valve covers.stick the hose inside the oil fill cap and pcv grommet.
you should have a good idea which valve it is before you pull off any covers....
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #15 of 21 (permalink) Old Jan 12th, 09, 09:23 PM
Russ
rafbody's Avatar
There are little metal clips that attach to the rockers made for adjusting the valves to minimize the oil spill on hydraulic cams. My father has a set thet I have used before with good results.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
