Cranking a motor on the stand? - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 11th, 09, 03:30 PM Thread Starter
Travis
blackl78's Avatar
My friend has a 427 sitting on a stand and wants to crank it over to do a compresssion test. Doesnt want to fire it, just crank it over. He has the main positive batery terminal ran to the starter solenoid and the negative side of the battery ground to the block. What else does he need to do? Do you need a coil hooked up some how?
Thanks!
Travis
67 L78
67 Vert
blackl78 is offline
post #2 of 10 (permalink) Old Jan 11th, 09, 04:01 PM
Dave M
Barefoot Dave's Avatar
Re: Cranking a motor on the stand?
Is this a brand new rebuild or a used engine? Either way I gotta wonder why he needs to do a compression test on a stand?
He definitely doesn't need a coil...or any spark plugs in to do it right, just some power to the solenoid to engage the starter.
Dave Miller
Barefoot Dave is offline
post #3 of 10 (permalink) Old Jan 11th, 09, 04:05 PM
NHBandit's Avatar
jump to the "S" terminal on the solenoid to crank it. That's about it. Or feed power to the coil, hook up a fuel line to the carb and annoy the neighbors... As Dave said no sparkplugs. To get an accurate compression reading you need a fully charged battery, all plugs removed & hold the carb wide open to let the air flow through.
NHBandit is offline
post #4 of 10 (permalink) Old Jan 11th, 09, 04:13 PM
I've cranked a few motors on hoists and stands it's easy. Since the battery is already hooked up (positive to starter solinoid terminal and Neg. to block), get a long screw driver and jump the positive terminal on the starter solinoid to the smaller 's' terminal about an inch away from it. Just be a little carfull when you do it, watch those fingers too!
*EDIT* NHbandit beat me to it.
1999 Lingenfelter H.O.S.S.
1969 Rally Grenn SS Camaro project (sold)
RIP John Lingenfelter
(Oct. 6, 1945 - Dec. 25, 2003)
tall guy is offline
post #5 of 10 (permalink) Old Jan 11th, 09, 04:34 PM Thread Starter
Travis
blackl78's Avatar
OK, I guess I need to be a little more specific. After reading some of the replys, maybe he cant do this.
He bought the motor froma guy and never heard it run. He just wants to check the compression to see if its in specs. Also it has no intake cam or lifters, can he still do a compression test without these?
Travis
67 L78
67 Vert
blackl78 is offline
post #6 of 10 (permalink) Old Jan 11th, 09, 04:37 PM
NHBandit's Avatar
no
NHBandit is offline
post #7 of 10 (permalink) Old Jan 11th, 09, 05:07 PM
If the motor is new, never been run, you probably don't have the full benefits of rings being sealed, so I would suggest running a leak down. Be safer. I have seen a few guys crank the motor and run it on a typical stand, but I would make sure I have some way to lock the motor down to keep from spinning or torquing over. Can you imagine a running motor spinning on an engine stand?
TC # 349
zdld17 is offline
post #8 of 10 (permalink) Old Jan 11th, 09, 05:14 PM Thread Starter
Travis
blackl78's Avatar
It is a used engine and it wont run, has no intake, cam or lifters /pushrods
Thanks!
Travis
67 L78
67 Vert
blackl78 is offline
post #9 of 10 (permalink) Old Jan 11th, 09, 05:21 PM
NHBandit's Avatar
Thanks!
Can't do a compression test with no cam, lifters, pushrods.. No way to get air in or out. I would bet it turns over pretty damn hard by hand even with all the valves closed unless the plugs are out of it.
NHBandit is offline
post #10 of 10 (permalink) Old Jan 11th, 09, 06:44 PM Thread Starter
Travis
blackl78's Avatar
Thanks guys, this has helped a bunch! And I just hit 500 posts WOOOHOOO!!
Travis
67 L78
67 Vert
blackl78 is offline
