Correct Crank Pulley Fit for 69 Big Block A/C? - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 11th, 09, 07:40 PM Thread Starter
JB
I just put a 427 in my 69. It has a/c and the pulley is 3 groove from a Chevelle PN 3937787 AC. There's hardly any room between the outernmost groove and lower cross support. The belt may even be able to rub once installed. I used the correct frame and motor mounts... Is the Camaro pulley typically smaller or the same as the Chevelle? It measure 7-11/16 inches across the diameter.
69RSMAN is offline
post #2 of 7 (permalink) Old Jan 11th, 09, 08:09 PM
Keith
Re: Correct Crank Pulley Fit for 69 Big Block A/C?
Mine is real close and is the correct one. It is hard to get the belt on but does not rub.
z10kl is offline
post #3 of 7 (permalink) Old Jan 12th, 09, 03:25 PM Thread Starter
JB
Thanks!
69RSMAN is offline
post #4 of 7 (permalink) Old Jan 12th, 09, 03:35 PM
Ron
I believe the Chevelle, Camaro and Corvette pully's are all the same. I run one in a 70Z BB and it's tight.
This was my 70 1/2 Z28
Z15CAM is offline
post #5 of 7 (permalink) Old Jan 13th, 09, 02:17 AM
Accroding to Jerry McNeishs' book, the 787 pulley is not right for a '69 car. I can't remember the correct pulley number off the top of my head, but I'll look it up later when I get home.
buenymayor is offline
post #6 of 7 (permalink) Old Jan 13th, 09, 10:25 AM
Paul
Know mine is a BB 68 Camaro wth a/c (short water pump), but the diameter of the third a/c pulley is 6 3/4".
Plenty of clearance to the crossmember. Correct pulleys per CRG. You could go there for your correct 69 a/c pulley numbers.
1962vette is offline
post #7 of 7 (permalink) Old Jan 13th, 09, 01:18 PM
Smile Re: Correct Crank Pulley Fit for 69 Big Block A/C?
TJS69 is offline
