Fuel Pressure Guage - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 12th, 09, 07:48 AM Thread Starter
Greg
Fuel Pressure Guage
I see alot of fuel pressure guages under the hood, obviously visible to see. I put one, non liquid filled and very cheap, on my car but it bounces like crazy so I'd like to replace it. It's a standard screw into a fuel block guage. Anyone want to recommend a guage, maybe what you're using and are happy with? Price and where to get would be very helpful too. Thanks guys...
Oh yeah, if you want to see what I have now I have pix in the Showroom, page 1, last pic on the bottom right. It's the red car with the dual side-by-side carbs. I think the Showroom may be reserved only for members though??? Thanks again...
Greg
greg1ontheedge is offline
post #2 of 15 (permalink) Old Jan 12th, 09, 09:17 AM
Re: Fuel Pressure Guage
I lost several of these hi dollar , liquid filled guages to needle bouncing, could not find the correct screw dampner setting. I went to elcheapo Holley dry gauge and it does not bounce. So far so good but the best set up I think , is the isolater type gauge that can be mounted inside vehicle. Little more bucks but its the end to under hood gauge fails, or it was for me. Just my 2 ¢
TC # 349
zdld17 is offline
post #3 of 15 (permalink) Old Jan 12th, 09, 10:35 AM
Charlie
Have you tried a liquid filled type gauge? I run this style and the needle is rock solid.
67CamaroRS/SS is offline
post #4 of 15 (permalink) Old Jan 12th, 09, 10:45 AM Thread Starter
Greg
Don/Charlie, thanks for responding. Charlie, could I ask you to maybe point me to a specific guage? Maybe one on Summit, or Jeg's or Rick's? Maybe the one you use that's rock solid? Again, thanks.....
Greg
post #5 of 15 (permalink) Old Jan 12th, 09, 11:43 AM
What I have used, http://www.jegs.com/i/NOS/741/15900/10002/-1#
What I am using now, http://www.jegs.com/i/Holley/510/26-500/10002/-1
When this fails, I will use this,
http://www.jegs.com/i/Auto+Meter/105/5411/10002/-1
With this, http://www.jegs.com/i/Auto+Meter/105/5282/10002/-1
TC # 349
zdld17 is offline
post #6 of 15 (permalink) Old Jan 12th, 09, 12:57 PM Thread Starter
Greg
The Holley you're using now looks like exactly what I need. 0-15 is perfect as I run 6-8 psi. I'll ask Jeg's to make sure this is liquid filled, don't want to waste $26. Thanks much Don....
Greg
post #7 of 15 (permalink) Old Jan 12th, 09, 01:22 PM
Banned
Ron
Badbird's Avatar
I have a non liquid filled Summit gauge which was bouncing like a son of a gun and the needle would not return to 0!....I disassembled the gauge and readjusted the needle and was successful!....The needle returns to 0 and no longer bounces!.....Give this a try before you purchase another one.
Badbird is offline
post #8 of 15 (permalink) Old Jan 12th, 09, 02:07 PM Thread Starter
Greg
Hmmm, how do you adjust the needle Ron? There's no adjustment screw or anything on the back, it's just a simple guage. The guage I'm using came with a really cheap dual inline carb thing, we've all seen I'm sure (chrome plated, woooooo). But yeah, start the car and the needle is going crazy even at idle. Thanks Ron.
Greg
post #9 of 15 (permalink) Old Jan 12th, 09, 02:18 PM
Banned
Ron
Badbird's Avatar
I don't know quite how to explain it but if you take it apart, you'll see a thin spring like thing, which the needle is attached too....I bent this slightly to put more pressure on the needle so it would return fully to 0 and it worked!....The needle never fluctuated or bounced around after that and is still accurate!....You have nothing to loose and should at least give it a try!
Badbird is offline
post #10 of 15 (permalink) Old Jan 12th, 09, 02:30 PM
Banned
Ron
Badbird's Avatar
Remove the cover and bring the needle up and see if it returns fully back to 0.....If it doesn't quickly return then you can bend the mechanism to put more pressure on the needle....I believe this is what causes the bouncing around because of lack of return pressure!....I hope you grasp what I'm trying to say!
Badbird is offline
post #11 of 15 (permalink) Old Jan 12th, 09, 02:33 PM Thread Starter
Greg
Well, probably won't get to it til the weekend but got nothin to lose. And the recommended liquid filled guage is like $27, probably $30 with shipping. I got no money to just waste if I got a part I can fix. Thanks Ron.
Greg
post #12 of 15 (permalink) Old Jan 12th, 09, 02:51 PM
Banned
Ron
Badbird's Avatar
You're Welcome Greg!.....Your thinking is just like mine!.....I had this nice chrome, yet defective, Summit gauge laying around for probably 10 years and really didn't want to buy one unless I really had too so that's when I decided to take it apart and fiddle around with it and fix it and it worked out excellent!
Badbird is offline
post #13 of 15 (permalink) Old Jan 12th, 09, 05:28 PM Thread Starter
Greg
Well, I'll be 'adjustin' before I'm 'buyin'. Thanks Ron, and as always this site is always here for ya.....
Greg
post #14 of 15 (permalink) Old Jan 12th, 09, 05:47 PM
Banned
Ron
Badbird's Avatar
You're welcome again Greg!.....I think it really pays to be mechanically inclined, eager to take things apart to see how they function then fix them with no instruction what so ever!.....It's truly a gift!
Badbird is offline
post #15 of 15 (permalink) Old Jan 13th, 09, 06:43 AM
Charlie
I run this one from my local race parts store, but I would think any liquid filled gauge would do the job. The liquid is what steadies the needle, but you need to be careful about extreme heat. The liquid is temp sensitive. Pressure builds and makes the needle read low at times. When this happens, simply carefully lift the rubber seal and equalize the pressure and it works perfectly again. If you mount it down near the frame rail, you won't have this issue. Mount it on your pressure regulator and down on the frame rail.
