What size and who's carb should i get - Team Camaro Tech
post #1 of 17 (permalink) Old Jan 12th, 09, 02:53 PM Thread Starter
carl
Question What size and who's carb should i get
I have a 383 with 11:1 compression, comp cams 306s, Trick Flow r215 heads, and a Team G intake. What size and what style of carb should i get. I race at the 1/4mile but i race at the 1/8th the most
carjai is offline
post #2 of 17 (permalink) Old Jan 12th, 09, 03:06 PM
BILL
SPARKY69's Avatar
Re: What size and who's carb should i get
WELCOME TO TEAM CAMARO!!!! 850 holley hp WITH A 1 INCH SPACER!!!! CARL I TALKED TO YOU ON TEAM NOVA...IS YOUR INTAKE OPEN AND IS IT HI RISE?? WHAT GEAR IS YOUR REAR THAT YOU ARE RUNNING!!!
SPARKY69 is offline
post #3 of 17 (permalink) Old Jan 12th, 09, 04:04 PM
750 Holley street and strip....850 Holley mostly strip
or
750 Mighty Demon strip or street
68 Camaro~LSx ~all motor
post #4 of 17 (permalink) Old Jan 12th, 09, 04:15 PM Thread Starter
carl
Its a single plain wnd-7530, the gears that i have now are 3.73
carjai is offline
post #5 of 17 (permalink) Old Jan 12th, 09, 06:59 PM
Robb
Look at one of these
http://www.aedperformance.com/HO.htm
or a factory Holley 750 HP series
67 Camaro Project in progress
98 Camaro Z-28
72 ChevellePump Gas 468
373/9.5" converter/ TH350
Best 10.70 @ 123
Creeper is offline
post #6 of 17 (permalink) Old Jan 13th, 09, 12:34 AM
Harley D
HarleyD67's Avatar
A Pro-Form 750 or 800. Or for a little more money the Holley 800 hp.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #7 of 17 (permalink) Old Jan 13th, 09, 04:53 AM
BILL
SPARKY69's Avatar
Carl, 750 wont be enough!! I got the same 383 set up only with dart pro 1 heads 750 wont cut it!! I run the 4150 holley 1000 hp on mine and love it ..only during heavy burn outs it will load up alil...but she will clear out fine..bill mtchell harecore racing makes a killer 870 cfm carb for $500.00,...
SPARKY69 is offline
post #8 of 17 (permalink) Old Jan 13th, 09, 09:37 AM
On this type of combination, if it is properly matched, a 750 usually works best. An 850/1000 will make slightly more top end power but usually be somewhat or even terribly rough on the low end and basically just kill low end torque. To be optimized the 850/1000 would need a very loose convertor and a lot of rpm to realize any real potential over the 750. I list the 850/1000 together because a standard Holley 850 and a 1000 HP are actually the same physical size. Be aware that carb cfm ratings are all over the map from manufacturer to manufacturer. Another option if you decide you have to have a 850 is to run one with annular boosters. These help with low speed response and flow slightly more than the 750, but not nearly what the 850/1000 will. Whichever manufacturer you choose be aware a 750 from each manufacturer will be different. The Demon's, and most ported holley's (AED, for example) will flow more air than the stock Holley without losing much, if any torque. Std holley has 1.375 venturi while Demon has 1.4 venturi. Most ported carbs are similiar to Demon. This is the way I would go on your combo.
800-233-0199 ext 457
vintagemotion is offline
post #9 of 17 (permalink) Old Jan 13th, 09, 09:58 AM
BILL
SPARKY69's Avatar
VERY GOOD ADVICE, BUT THE 750 ISNT ENOUGH AIR(CFM) FOR HIS HEAD COMBO, IT WILL RUN OUT ON HIM..I AGREE THE 850 IS PROBALLY THE BEST CHOICE....
SPARKY69 is offline
post #10 of 17 (permalink) Old Jan 13th, 09, 04:05 PM
750-850 Holley should be good
Demons flow higher than Holleys of the same size (Demon 750 flows in the 930 range Vs. Holley 700 range)
post #11 of 17 (permalink) Old Jan 13th, 09, 04:21 PM
george
x2^..This carb is a nice piece..I hated to part with mine.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #12 of 17 (permalink) Old Jan 13th, 09, 08:56 PM
Harley D
HarleyD67's Avatar
Same reason I recommended the Pro-form over the Holley the Pro-form 750 race carb is less expensive and flows 830cfm.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #13 of 17 (permalink) Old Jan 14th, 09, 05:05 AM
BILL
SPARKY69's Avatar
Demon is no comparison to a holley or proform..try getting parts for them in your town where you live!!you cant, but a holley you can!!
SPARKY69 is offline
post #14 of 17 (permalink) Old Jan 14th, 09, 07:58 AM
Charlie
I am a firm believer in the Q-Jet. A properly tuned and modified Q-Jet can easily support 800+ hp. Just ask the guys running the Nostalgia class and lifting the front end. You get the best of both worlds. Small primaries give great throttle response and MPG while the HUGE secondaries provide GREAT power.
67CamaroRS/SS is offline
post #15 of 17 (permalink) Old Jan 14th, 09, 11:53 AM Thread Starter
carl
i think im gonna send the heads back and get a set of dart pro1 200s
carjai is offline
