96 LT1 motor/ 2nd gen - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 13th, 09, 08:25 PM Thread Starter
This is motor towards Trans and driveline, but it also is leaning towards engine too.
I have a 96 LT1 motor and a 74 muncie four speed transmission that is going in my 74 Camaro.
These are my questions:
Can I use a clutch disk for 74 muncie with the 96 LT1 flywheel and pressure plate? Also with out the hydralic set up?
OR.... Where can I get a clutch and pressure plate for the muncie trans that will match up to the 96 LT1 factory flywheel?
Last..... Or where can I find a older style flywheel (74 up till 2nd gen motor) that matches the 96 LT1 bolt pattern?
I know and have seen where these application have been mated together, but I can not find where I can get my answers or parts from. Any info, part numbers, and places I can get my parts will be really helpful.
joe_74_camaro is offline
post #2 of 2 (permalink) Old Jan 13th, 09, 09:12 PM
Re: 96 LT1 motor/ 2nd gen
I'm sure the guys will correct my misses here...
You have to use a flywheel for a Gen2 (one peice rear main seal) block.
Any standard 10.4" pressure plate and matching disk will bolt to this flywheel, and be compatible with a normal throiwout bearing and mechanical clutch.
An LT1 bellhousing won't match up to the muncie, but I think a normal early 403 or similar bellhousing for a 10.4" clutch will make it all fit together.
