oil leak 67 rs camaro 5 speed - Team Camaro Tech
post #1 of 1 (permalink) Old Jan 14th, 09, 06:01 PM Thread Starter
well this is for some one experinced. i have a 350 engine about 4000 miles on it. ihad a oil leak when i bought it it has a 88 camaro 5 speed in it. i replaced pan and fel pro 1 piece gskt replaced rear main with fel pro offset seal. it leaks out the bell housing slow drip every time i start it i can feel it on inside lip only on the inside of bell housing. i looked up where the main seal is no oilresidue on pan side or any thing dripping down outside of bell checked oilpressure line off engine no leaks i have car on javkstands while running. is it possible for the transsmission front seal to leak down thru bell housing inside .bare in mind i have not engaged tranny still in nuetral. any ideas im stumped . if its a rear main again why dont i see it between pan and bell housing absolutely dry up there thanks for any help larry
speedster857 is offline
