95 Z28 fuel pump R&R - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 14th, 09, 11:08 PM Thread Starter
Does anyone have any good suggestions for removing the old fuel pump and installing a new one. I've been told that I have to drop the rear end, cut the exhaust system, and remove the fuel tank to get to the fuel pump unit. What about cutting through the floor board?
ManRam99 is offline
post #2 of 6 (permalink) Old Jan 15th, 09, 04:20 AM
Re: 95 Z28 fuel pump R&R
You will have to make a large hole to get sending unit out. The lines are long and
you need to turn the sending unit out to remove from tank.
john68 is offline
post #3 of 6 (permalink) Old Jan 15th, 09, 04:47 AM
BILL
SPARKY69's Avatar
Dont cut the floor..drop the rear and pull it out the right way, it is not that bad..a friend and some tools and a couple of jack stands!!
SPARKY69 is offline
post #4 of 6 (permalink) Old Jan 15th, 09, 04:41 PM Thread Starter
My better judgment say's do it the right way. Thanks for the advice. Just thought I would check to see if there was a better way.
ManRam99 is offline
post #5 of 6 (permalink) Old Jan 15th, 09, 07:01 PM
Lonnie
Lonnie P's Avatar
You should not have to cut the exhaust... it will be tight, but by removing the mounts it should be close.
When you drop the rear, disconnect panhard, the swaybar from the frame & the lower shocks mounts to get the rear down further, but be careful not to over-extend the brake lines.
Lonnie P is offline
post #6 of 6 (permalink) Old Jan 26th, 09, 01:50 PM Thread Starter
Thanks for all the help guys. I dropped the fuel tank the right way, and was able to get it all back together the right way. I am taking it to the shop on Wednesday because it still is not running the way it used to. I get an EGR fault code. I've checked for vacuum leaks and electrical problems and found none.
ManRam99 is offline
