roller cam assy & breakin oil - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 15th, 09, 04:33 PM Thread Starter
Is it good to use gm eos in the oil during break in of my comp cam xr276hr cam, what oil weight should I use, and what kind of assy lube on the cam I wanted to use cranes 99002-1moly lube but in summit it says not for roller cams, I tried to call comp, but was on hold forever
jdbr1 is offline
post #2 of 6 (permalink) Old Jan 15th, 09, 04:50 PM
richard
z28rich's Avatar
Re: roller cam assy & breakin oil
if you have a roller cam,you dont need beakin oil or anything special.only flat tappet cams require oils with extra z&p.
Richard
1969 Garnet Red Z/28-RS with Black stripes
and Black Deluxe Int. I found my build sheet
2012 Shelby SVTPP GT500 race red with dash signed by Caroll Shelby
RIP Mr Shelby
z28rich is offline
post #3 of 6 (permalink) Old Jan 15th, 09, 05:02 PM
Enjoy one of the benefits of the roller world-no break in jitters.
douse it with oil and start it up-Prelube the motor if posible.
What is the cam going in?
yellow heap is offline
post #4 of 6 (permalink) Old Jan 15th, 09, 08:22 PM Thread Starter
its a 350 with vortec heads cam is a comp cam xr276hr 502/510 lift
lobe sep 110 224/230 duration @50 CENTER LINE 106
jdbr1 is offline
post #5 of 6 (permalink) Old Jan 15th, 09, 08:31 PM
Should go like stink!
post #6 of 6 (permalink) Old Jan 15th, 09, 09:59 PM
That's the same cam I have in my zz4. You'll like it's nice little lope.
67RS-zz4 w/ trickflow heads 276hr cam air gap 780 Pro Systems TexRacing 4spd AGR steering SCAT procars 12 bolt eaton posi 3.73's SSBC all around, TT2's Dakota Digital Painless DSE hinges
Mike's67 is offline
