Ceramic ret. block on firewall - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 17th, 09, 07:12 AM Thread Starter
Larry
What is the white ceramic retangle block on firewall.
I'm installing it after 5 yrs and I can't remember how it hooks up to the distributor and coil. I would like to install it this morning so I could crank my engine.
IT KEEPS ME GOING
69 Z/28
711 67 67
02D X33
69Z28X33 is offline
post #2 of 5 (permalink) Old Jan 17th, 09, 08:11 AM
Re: Ceramic ret. block on firewall
It is the ignition input power resistor, generally used for aftermarket coils, Accel 14001 comes to mind, the big yellow coil. OE wire for ignition is a cloth covered wire - resistive wire.
In OE set-up, the cloth wire would be hooked up to the + coil terminal and distributor on the - terminal. With the ceramic resistor, cloth wire to one terminal of the resistor, a lead from the other resistor terminal to the + coil terminal, then the - terminal to the distributor. The yellow wire from the starter solenoid would go to the + coil terminal.
post #3 of 5 (permalink) Old Jan 17th, 09, 08:35 AM Thread Starter
Larry
Thanks Everett#2390.
Thats just the info I needed. I was looking through search and saw your name and thought about sending you a message.
IT KEEPS ME GOING
69 Z/28
711 67 67
02D X33
69Z28X33 is offline
post #4 of 5 (permalink) Old Jan 17th, 09, 08:38 AM
You're welcome.
post #5 of 5 (permalink) Old Jan 17th, 09, 08:48 AM Thread Starter
Larry
Originally Posted by Everett#2390 View Post
You're welcome.
By the way, is that a resent pic of you in your profile? You look young in that pic. with all that dark hair with no gray.
IT KEEPS ME GOING
69 Z/28
711 67 67
02D X33
69Z28X33 is offline
