Rochester 4 bbl carburetor linkage - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 17th, 09, 08:28 PM Thread Starter
Man....this is killing me. I'm doing a resto on a 67 Camaro with a 327 with Rochester 4bbl carburetor and can't seem to find the correct carburetor linkage. Ordered the repop linkage from Ricks and it did'nt fit. Then I ordered the universal linkage from Ricks, and it didn't fit either. Does anyone out there have the correct linkage? Something OEM or NOS perhaps.
Thanks,
Eric
eschroeder is offline
post #2 of 6 (permalink) Old Jan 17th, 09, 09:39 PM
Smile Re: Rochester 4 bbl carburetor linkage
What is it, that you are looking for ? The throttle rod ? I am currently using the one that came with my car (it is a universal, the original is long gone). I have seen many that would work at NPD, Classic, etc.
TJS69 is online now
post #3 of 6 (permalink) Old Jan 17th, 09, 11:57 PM
Charlie
If you are talking about the accelerator rod, I got mine from CLassic Industries and it fit perfectly. Here is the part number for the rod I used:
http://classicindustries.tv/controll...rchCatalogId=2
67CamaroRS/SS is offline
post #4 of 6 (permalink) Old Jan 18th, 09, 08:37 AM Thread Starter
Thanks...I order the throttle linkage from classic industries. Keep your fingers crossed.
Eric
post #5 of 6 (permalink) Old Jan 18th, 09, 09:45 AM
Charlie
If you are running a Q-Jet then it should fit perfectly.
post #6 of 6 (permalink) Old Feb 8th, 09, 04:52 PM
Charlie
Eric,
What intake are you using on your engine? I want to change over to a Q-Jet for my 327 and need to know which intake to use. Thanks
Charlie
cdaubs is offline
