Will a truck oil pan work in a 69? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 19th, 09, 06:52 AM Thread Starter
Patrick
I have a 454 that I am putting in my camaro and wonder if the oil pan is going to clear.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #2 of 6 (permalink) Old Jan 19th, 09, 07:19 AM
Re: Will a truck oil pan work in a 69?
The pan that was on my '75 454 p/u engine does. I cross referenced it in a Hollander and it's the same pan as a '69 Camaro BB.
4-quart pan.
pdq67
post #3 of 6 (permalink) Old Jan 19th, 09, 09:31 AM
Kevin
The "truck pans" I have would probably not fit in a stock Camaro subframe. It depends on the size of the sump. If it is around 11 or 12 inches front to back, it's a truck pan and holds a couple more quarts than a car pan, which would measure around 10 inches.
Autosmiths, LLC
'69 X44, stock 350 (for now), TH350, 3.70:1 gear 8.5" 10 bolt, Auburn Posi.
speedshifter is offline
post #4 of 6 (permalink) Old Jan 19th, 09, 03:12 PM
6 or 7-quart P/U pan no, the front sump hit's the S/F.
pdq67
post #5 of 6 (permalink) Old Jan 24th, 09, 08:53 PM
Phil
I put a 454 truck motor in my 67 camaro and found that the front of the sump on the pan was against the drag link when I cut the wheel all the way to the left. I tried to modify the pan by heating it and trying to dimple it. I ended up pulling the engine and getting a 4 qt summit pan. It worked great. The truck pan also hung about 1" lower than the crossmember.
phils67camaro is offline
post #6 of 6 (permalink) Old Jan 24th, 09, 09:45 PM
Darko
i put in a 454 from a 89 chevy truck, the pan on it worked fine
darko is offline
