What kind of times do you think this would run - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 19th, 09, 07:46 AM Thread Starter
It will be going in a 1969 Camaro..7oor4 trans....373 gears.. It has 427hp 468torq.
  • Select Hi Tin block 4 bolt main machined 030-040-060 - 750.00
  • align bore and or check for run out.full race clearancing
  • Mag Check-preasure check ... $40
  • Hot Tank - Jet Wash .... $50
  • Bore Torque Plate Hone ... $125 Torque Plate Gives True Finish
  • Clearance block - -casting flash only n/c..
  • shotpeen rods... $45
  • Dynamic balance assembly.. $125
  • File fit rings - blue print clearance... $90
  • press - pistons to rods... $45
  • Install cam bearings - freeze plugs... $45
  • Port blue print cylinder heads... $200
  • Final assemble full rotating and top end
    • Parts including final torque - clearance - and geometry of all parts... $200 total labor you could spend 1700.00
All new Performance Internal Parts
  • Speed Pro hyperutectic.. pistons 9.9 to 1 piston set[ 289.00 PUMP GAS OK
  • Eagle steel crank with superior wear sized and indexed.399.00
  • Childs & Albert - zz gapdura Moly File Fit Rings... $159.99 [provides the ultimate in ring sealing making more power!!
  • Durabond - cam bearings... 49.99
  • gm pink forged steel rods 199.00
  • ARP - wavelock - rod bolts... $59.99
  • Clevite- -bearings tri metal 77 - rod and main... $99.99
  • comp cams custom hi output cam lifter set .. 189.00
  • Cloyes - true roller set... $59.99
  • Comp - cams cam locks... $4.99
  • comp cams xe chrome moly pushrods 99.99
  • Dyna gear race - oil pump... $49.99
  • Dyna gear - pickup... $29.99
  • ARP - steel drive... $13.99
  • After market - oil pan. baffeld 5 qt $59.99
  • After market - timing cover... $19.99
  • pioneer/arp - head bolts... $59.99
  • ARP/ - .. 39.99
  • Fel Pro blue - gasket sets... 89.99 - TOTAL PARTS YOU COULD SPEND BUILDING YOURSELF 3400.00 INC HEADS COST BELOW
Power Making Featured Parts
  • ALL NEW VORTEC STYLE ALUMINUM HEADS ... $858
    • Features - - -GM BACKCUT 2.0/1.55 valves plus ... 1.25 springs 7 degree super locks comp cam parts.....gasket match p.c seals.chrome moly retainers WE FOUND THESE HEADS WORK BEST AS CASTED WITH BACK CUT VALVES. NO TORQUE LOSS
  • hi perfromance roller rockers-1.6 ratio self aligners american made... $249.99
  • CUSTOM SPLIT PROFILE CAM- -muscle car cam ,lopey idle PLUS MATCHING POLISHED RPM INTAKE
  • Features - 110 center line 488 - 490 lift corrected 1.6 ratio . 226/228 dur @ 050 awesome power range 2000 stall. lopey muscle car idle. 100% streetable and will run vacum access
bnbpaintballer is offline
post #2 of 15 (permalink) Old Jan 19th, 09, 08:30 AM
Paul
Re: What kind of times do you think this would run
High 12's/low 13's
1969 RS/SS DROPTOP is offline
post #3 of 15 (permalink) Old Jan 19th, 09, 12:40 PM Thread Starter
Cool, I could live with that.
Thanks,
post #4 of 15 (permalink) Old Jan 19th, 09, 04:56 PM
Robb
I will say low 13's Let us know how it does !
67 Camaro Project in progress
98 Camaro Z-28
72 ChevellePump Gas 468
373/9.5" converter/ TH350
Best 10.70 @ 123
Creeper is offline
post #5 of 15 (permalink) Old Jan 19th, 09, 05:04 PM Thread Starter
I havent totally decided on it yet. I have a couple I am looking at and I have a couple of months to choose.
post #6 of 15 (permalink) Old Jan 19th, 09, 06:44 PM
  • ARP/ - .. 39.99
Watch what your doing here!
vortecpro is offline
post #7 of 15 (permalink) Old Jan 19th, 09, 07:03 PM
Skip
Skeeter55's Avatar
Mark thank you for the info on my soon to be 496 build that now is a 498 build 454 70 over, Race Rite 270cc Oval with a comp XR274R (probably could have went with a more aggressive cam) and scats stroker forged crank & rods, SRP pistons, Crowers hppo lifters, Comp pro Magnum 1.7 rockers, 10.5 compression, air gap, 850 holly dpdf, msd 6al, super comp hooker 2x3.5 that Mike Lewis has help put a combo together with George from S & S Auto Motive (closer to me) also he goes way back as far as racing one of there drag cars... I just wanted to thank you again, i hope something out of this goes both you and Mikes way, you guys have great info on the Team Chevelle site and its a honor to have you share some info over here... What do you think she will see on hp & tq, cam 236/242 @50 639/646 lift rpm 2000 to 6200rpm. Also with 373 what would my time be considering a 4-speed 12 bolt 373 slapper bars and 9" slicks.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #8 of 15 (permalink) Old Jan 19th, 09, 07:03 PM
Where is it coming from is my first question. Reputation means a lot more than parts in my opinion. the next question is what the hell are some of those parts doing in that lineup, the best thing to do is go down the list and itemize everything for each of your choices, because some of the generics on that listing are iffy, "Eagle Steel Crank" no grade listing or steel quality? and the GM Pink Rods, why not go with an Eagle Rotating Assembly and cut out the garbage of miss-matching and out of balancing due to overweighted rods. And anytime i see the, "You could spend XXX Dollars elsewear" crap, I can't help but think Infomercial, and nothing good ever came from those, not even vince and his sham wow. Another question is, What kind of rearend you have under there? anything less than well built 12 bolt and you could be a tow truck from Moserville. Engine sounds iffy to me, but hey, What would I know, I just have a Degree, an ASE patch, a big Goodwrench logo on my shirt, and a Chrysler one right next to it.
Racing_To_Win is offline
post #9 of 15 (permalink) Old Jan 19th, 09, 07:29 PM
Skip
Skeeter55's Avatar
I cant wait to run this thing.
post #10 of 15 (permalink) Old Jan 19th, 09, 08:12 PM
george
[quote=Skeeter55;1142542]Mark thank you for the info on my soon to be 496 build that now is a 498 build 454 60 over
Skip..are you going to a 4.320 bore for 498 cid?That would be a .070" overbore.not .060"^.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #11 of 15 (permalink) Old Jan 19th, 09, 08:19 PM
Skip
Skeeter55's Avatar
[quote=fatblock;1142614]
Yeah thats what my builder said, so i guess its 70 over can you get that 498, and he said next go around i could make it a 505 cid.. I think this is the piston http://www.jegs.com/i/SRP/867/212157/10002/-1
post #12 of 15 (permalink) Old Jan 19th, 09, 08:59 PM
george
[quote=Skeeter55;1142620][quote=fatblock;1142614] Yeah thats what my builder said, so i guess its 70 over can you get that 498, and he said next go around i could make it a 505 cid.. I think this is the piston http://www.jegs.com/i/SRP/867/212157/10002/-1[/quote
That piston ^ fits a 4.310 bore.With a 4.250 stroke..you have 496 cid.
To hit 505 cid with a 4.250 arm..you would require a 4.350(100 over)bore.
A .070" overbore will grab 498 cid.poking out a 454 to 4.350" is not unheard of if there is no core shift and the sonic check shows sufficient meat.Are you sure you are going .070" over?
George
68 Camaro
fatblock is offline
post #13 of 15 (permalink) Old Jan 20th, 09, 08:04 AM
Skip
Skeeter55's Avatar
[quote=fatblock;1142670][quote=Skeeter55;1142620]
George i will find out the details today, all i know is he said that it is 498 not 496 so what ever he did thats what he came up with, i guess that early 70s block has allot of meat on it... With my combo what do you think my car will run 69 Camaro...Thanks Skip
Your right its 0.70" over @ 4.320 he says the bolck can go a 100 over.
post #14 of 15 (permalink) Old Jan 20th, 09, 09:58 AM Thread Starter
Alright but can you be more specific? I know very little and all info is helpful.
post #15 of 15 (permalink) Old Jan 20th, 09, 10:17 AM
Skip
Skeeter55's Avatar
Brian im going threw the same thing and im man who can wrench but don't want to do all the guessing that these builders have done for many years... If i were you i would check out the www.teamchevelle.com go to forums performance section and read some of the threads, you will see (VORTECPRO Mark) and (WOLFPLACE Mike) given some great advise and customer service.. Call them and the will help you out, they helped me.
