69 Camaro SS 350 fuel line install - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 19th, 09, 07:35 PM Thread Starter
Doug
Hey all I have read a few posts dating back awhile on the topic of fuel line replacement on a 1969 Camaro. Was wondering if anyone else had any tips or tricks in doing the install. My Camaro is a '69 SS 350 with the fuel and vapor return line. I do not have a lift. Just a jack and some jack stands. Any info would be great if anyone has experience doing the job and how you did it.
-Doug
Mr. Super Sport is offline
post #2 of 12 (permalink) Old Jan 20th, 09, 09:15 AM Thread Starter
Doug
Re: 69 Camaro SS 350 fuel line install
Anyone?
post #3 of 12 (permalink) Old Jan 20th, 09, 09:59 AM
Well, I did one on a '67 I had, changed from OE 5/16" to 3/8 inch and what I seen to be the hardest part was the line under the pass front spring mount.
It appears the fuel line went first, then the springs/rear axle.
post #4 of 12 (permalink) Old Jan 20th, 09, 10:16 AM
Jonesy's Avatar
I did mine when I had the car apart and had the advantage of rolling the subframe to the body. I put the lines on the body first, then guided the line to the inside of the subframe as I rolled the subframe towards the body. I know this doesnt probably help in your situation. I havent been under my car for awhile, but I would think you could route the front first with a little bending and massaging and then the rear lays out pretty easy. My brake lines came in a box bent to reduce for shipping. I just took and bent them back using my old lines as a guide.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #5 of 12 (permalink) Old Jan 20th, 09, 12:24 PM Thread Starter
Doug
Thanks guys for the information. Will give it a try here in the next few days.
-Doug
post #6 of 12 (permalink) Old Jan 20th, 09, 12:37 PM
Skip
Skeeter55's Avatar
I just did mine last weekend... 2-guys, the fuel line come bent into a U-shape leave it that way, 1-start to feed it in the front between the frame with one person guiding it from causing any damage, 2-then working towards the rear of the car before you straighten the line start to feed it under the rear frame to the gas tank, 3-mount it to the tank and work back to the front on straightening and clamping down... My motor is out but this is the best way to complete the installation.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #7 of 12 (permalink) Old Jan 20th, 09, 08:40 PM Thread Starter
Doug
Thanks for adding to the info Skip. I appreciate all of your help.
-Doug
post #8 of 12 (permalink) Old Jan 20th, 09, 09:14 PM
Skip
Skeeter55's Avatar
-Doug
My pleasure, just take your time and make sure you tank is empty first. A little of twisting and pushing/pulling you will be good to go.
post #9 of 12 (permalink) Old Jan 25th, 09, 03:09 PM Thread Starter
Doug
Thanks again guys for the info. Installed the new fuel and vapor return lines yesterday along with the help of a friend. It only took about an hour and a half. We were amazed at how easy they came out and went back in. Jacked the car a couple feet off the ground and removed rear passenger wheel assy. That was all that we removed. This car is all together so was very pleased it went so smooth. If anyone is thinking about doing this job go ahead and do it. Thanks again.
-Doug
post #10 of 12 (permalink) Old Jan 25th, 09, 03:15 PM
Skip
Skeeter55's Avatar
Thanks for the update and glad to see it went easy for you. How long did it take to pump the fuel up threw the lines. Just curious because i haven't got that far yet.
post #11 of 12 (permalink) Old Jan 25th, 09, 05:00 PM
JcGc's Avatar
Skip,
When I did my lines it took maybe five to ten seconds of cranking to get the fuel up to the carb.
1969 Camaro
JcGc is offline
post #12 of 12 (permalink) Old Jan 25th, 09, 06:10 PM Thread Starter
Doug
Right around the time John stated above.
-Doug
