Anyone using a Pertronix system instead of points ??? - Team Camaro Tech
post #1 of 16 (permalink) Old Jan 20th, 09, 07:23 AM Thread Starter
Bob
I'm getting ready to fire up my engine for the first time and I'm a little hesitant to use points. Its a restoration so an HEI is out of the question as I need the original distributor look. Has anyone used the Pertronix electronic conversion kit ???? What are the pro's and con's of this system. I know it keeps the "stock" look which is what I'm after but what about reliability ?? does it use the stock coil ??
Thanks for any and all info..........
bob
Bgonz 69 is offline
post #2 of 16 (permalink) Old Jan 20th, 09, 07:48 AM
Banned
Rob
satz28's Avatar
Re: Anyone using a Pertronix system instead of points ???
bob
I had one on my 302 2-3 years and never had a problem.
satz28 is offline
post #3 of 16 (permalink) Old Jan 20th, 09, 07:50 AM
I've had one in my Corvair for many years with no problems
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #4 of 16 (permalink) Old Jan 20th, 09, 08:15 AM
Joe A
I put a complete Pertronix system on my 350, Dizzy and coil and I had no problems with the initial fire-up and the occasional start-up. You can see it and hear it running in my break-in vid on my Photobucket account.
1967 SS 350 Clone ( not hiding it )
Never Ending Project
camjoe63 is offline
post #5 of 16 (permalink) Old Jan 20th, 09, 08:15 AM
Search "pertronix" here, lots of threads asking the same question.
https://www.camaros.net/forums/showth...ight=pertronix
Lots and lots more for the reading.
Eric
Eric Kammerer is offline
post #6 of 16 (permalink) Old Jan 20th, 09, 08:42 AM
Keith
I put one on my sb350 last year and it worked great. I did use the stock coil. It was pretty simple because even I could install it.
BK69 is offline
post #7 of 16 (permalink) Old Jan 20th, 09, 09:46 AM Thread Starter
Bob
Originally Posted by Eric Kammerer View Post
Thanks for the links Eric. I can't do a search on my school computer But your links work perfect
Thanks for all the info guys.............
bob
Bgonz 69 is offline
post #8 of 16 (permalink) Old Jan 20th, 09, 11:04 AM
I stopped using the drop in ignition systems a few years ago, went with Dave's small body HEI. Although it doesn't appear fully stock, the module is visible outside the distributor, it is a far superior system to any and all of the drop in's, including the Pertronix. If you are doing a very historically correct system, his conversion may not be for you, appearance wise.
There is a picture of one of the Chevy HEI conversions he does on the left side of his web site, davessmallbodyheis.com He can also send you more pictures of his conversion, ask for them at [email protected]
Regards,
Milton
The Devil's advocate is offline
post #9 of 16 (permalink) Old Jan 20th, 09, 11:08 AM
Brett
Yes and it works great. I did use the pertronix coil but it looks factory.
Brett
gm torch red is offline
post #10 of 16 (permalink) Old Jan 20th, 09, 11:15 AM
67 Camaros Rock
Joe Harrison's Avatar
I have had a pertronix in my 67 since 1997 with no problems.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #11 of 16 (permalink) Old Jan 21st, 09, 09:08 AM
I have one in my 65 Mustang with a 302 and it has worked fine.
deerhunter is offline
post #12 of 16 (permalink) Old Jan 21st, 09, 09:11 AM
SCOTT
on another note how about hook up on the factory tack in a 67? same as points?
thx scott
KAWSAM62 is offline
post #13 of 16 (permalink) Old Jan 21st, 09, 09:40 AM
Will
What are going to do with the car? You will have to put a "filter" inline to use the factory tach.Do a search on that. I was in the same boat a month ago , I just went with a good set of points.
Hatman is offline
post #14 of 16 (permalink) Old Jan 21st, 09, 02:22 PM
SCOTT
SHOW AND CRUISE, the car it has a msd6al? and a pertronics conversion in the distributor and a msd adapter of some sort to run the sun 2 tack on the colume,(po) im putting the factory style in dash tack so im gonna need to figure out the wiring with all this extra stuff.
any ideas
scott
KAWSAM62 is offline
post #15 of 16 (permalink) Old Jan 21st, 09, 06:32 PM
Brett
The tach hooks up just like it does from the factory. I did not have to put a filter in line on mine and it works fine.
Brett
