big block exhaust manifold 69 camaro - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 21st, 09, 01:18 PM Thread Starter
I have a 69 camaro 4speed that i put a 454 into it, I had headers and they hung up on the power steering box so i purchased cast iron exhaust manifolds for it. I used an engine lift to jack the engine up in order to get the left side on which i was able to instal but they still hang up on the steering box and than i can't get the engine mount to line up, I am about to give up what am i doing wrong. Suggestions please, Thank you
kaaduba is offline
post #2 of 13 (permalink) Old Jan 21st, 09, 01:25 PM
Banned
Ron
Badbird's Avatar
Re: big block exhaust manifold 69 camaro
You'll need to install frame mounts for a big block, which will offset the motor.
Badbird is offline
post #3 of 13 (permalink) Old Jan 21st, 09, 01:40 PM
Skip
Skeeter55's Avatar
X2 it will kick the driver side up and over just a bit... If you had a small block in it before then chance are you have the small block frame mounts.. Big block frame mounts very noticeable because the driver side is shorter then the passenger side.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #4 of 13 (permalink) Old Jan 21st, 09, 01:45 PM Thread Starter
i already changed the mounts to big block mounts. thanks
kaaduba is offline
post #5 of 13 (permalink) Old Jan 21st, 09, 01:45 PM Thread Starter
mounts already changed to big block, thanks
kaaduba is offline
post #6 of 13 (permalink) Old Jan 21st, 09, 01:49 PM
Skip
Skeeter55's Avatar
Are you talking about the motor mounts or the metal frame mounts. The metal frame mounts are what bolts to the frame and the motor mounts bolt to the motor and then sets in to the frame mounts with a large bolt and nut to bolt together.
post #7 of 13 (permalink) Old Jan 21st, 09, 03:33 PM Thread Starter
Skeeter, i am talking about the frame mounts, they are for big block i changed them. You never replied what was on your car as far as headers etc. Thanks
kaaduba is offline
post #8 of 13 (permalink) Old Jan 21st, 09, 03:43 PM
Smile Re: big block exhaust manifold 69 camaro
Did you chance your transmission crossmember to a big block crossmember also ? It must also be changed to match the offset of the engine. Do you have the correct exhaust manifolds ?
TJS69 is offline
post #9 of 13 (permalink) Old Jan 21st, 09, 03:52 PM
JB
The incorrect exhaust manifolds for pass cars/trucks will point downward at the oil pan and may hit the steering box, instead of pointing more outward towards the fender like the correct ones. I just went thru the same issue (except I didn't install due to finding out it could be an issue, but will try tonight to see if same results occur). I got the correct ones and will hang them too tonight to see the difference.
See my blog from 2 weeks ago in this engine section regarding BB manifolds
69RSMAN is offline
post #10 of 13 (permalink) Old Jan 21st, 09, 03:58 PM
Skip
Skeeter55's Avatar
I sent 2 PMs did you get them, basically ive had headers on my BBC (don't know what they are) but my motor is now being rebuilt and i have purchased the Hooker Super Comps part# 520-2205-1
post #11 of 13 (permalink) Old Jan 21st, 09, 04:38 PM
I used my stock 350SS's cross member by just kicking my M-20's tailhousing over and then installing a 3-hole poly tranny mount using one bolt in the center hole in the mount and through the pass. side cross member hole fine!
My stock Muncie shifter works fine too!
pdq67
post #12 of 13 (permalink) Old Jan 22nd, 09, 01:22 PM Thread Starter
thanks, i did not change the cross member to a BB one, i will look into this. Thanks
kaaduba is offline
post #13 of 13 (permalink) Old Jan 22nd, 09, 01:38 PM Thread Starter
these are new manifolds bought from DR classics for BB engine left side manifold number is 3909879/ LH1. I did not change the crossmember on this car, it was a small block, it has a four speed transmision also. Please let me know on how your project goes and want you did to get them on. Thank you
kaaduba is offline
