I need help 2 - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 22nd, 09, 06:53 AM Thread Starter
Question I need help 2
I really donít have a budget all my money I make goes into the car its all I care about right now. I want the car to be driven a lot but fast on the track and on the street. What I need help on is what kind of cams, rods, and pistons. I donít know much about the ratios or what would work good together. I would like something that I could easily put a super charger on when I can finally afford one. I heard that would be the easiest route to go on my 81. I have a 350 small block and a th400trans
seescarswhensleeps is offline
post #2 of 3 (permalink) Old Jan 22nd, 09, 08:40 AM
Re: I need help 2
That is really an open-ended question. If you are positive you are going to supercharge it, you will want to build it different than NA. You will want a strong bottom end using forged parts especially if you plan on a lot of boost. If you are planning on replacing the bottom end anyway, you might want to check into a 383 rotating assembly. If you are planning on NA you will want the compression not over 10-1 unless you are planning on using aluminum heads. Lots of variables here.
deerhunter is offline
post #3 of 3 (permalink) Old Jan 22nd, 09, 02:27 PM
Re: I need help 2
Well, sounds like ya really want to go fast...but also take into consider the safety side of the go fast equation... like bigger rotors and such.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
