Spark Plug Selection - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 23rd, 09, 05:41 PM Thread Starter
Chris
Hatya's Avatar
As you may have read late last year i was going to change my heads on my 327 in my 69. I ended up getting a pretty sweet deal on a set of Performer RPM heads. The manual for these calls for a Champion spark plug RC-12YC, I prefer to use an AC Delco plug myself.
With these heads we calculated 9.5 CR, Im curious if this plug part number is a good start or if i should be looking at a different heat range to get started. I would like to get the right plugs the first time if possible,
If you need to know the cam/carb info i can post that to.
Hatya
Daily Driver
327 9.6:1, Performer RPM Heads, 200R4, 3rd Gen P/S Box
Hatya is offline
post #2 of 9 (permalink) Old Jan 23rd, 09, 10:36 PM
The Driver
Re: Spark Plug Selection
AC R44S is what I would run, IF you have 1969 dated heads. Around 1970-71 Chevy changed to Taper-seat plugs.
Champions: never!!!
If your heads take taper-seat, then use AC R44TS.
Wooderson is offline
post #3 of 9 (permalink) Old Jan 24th, 09, 10:58 AM
Banned
Ron
Badbird's Avatar
You can't go wrong if you use the gasketed spark plug that Edelbrock recommends which in your case would be the Champion RC-12YC....They would be the correct heat range for your application....This is what I done when I was running a pair of these heads on a BBC, they burned clean and I never had a spark plug fouling problem!
Badbird is offline
post #4 of 9 (permalink) Old Jan 24th, 09, 03:00 PM
Stupid as this sound's, I personally like Autolites!
It's as tho way back then when I worried about stuff like this, they were a schosh warmer or colder then AC's or Champions.
pdq67
post #5 of 9 (permalink) Old Jan 24th, 09, 04:17 PM
pdq67
I like Autolites also, Might look at a 4275 Autolite. I never had problems keeping them clean.
TC # 349
zdld17 is offline
post #6 of 9 (permalink) Old Jan 26th, 09, 07:29 AM
Charlie
I run the E3 Diamond Fires. They are the ONLY plug I have run that actually do what they say. More power, easier starts and better idle. I swapped out my R44ts for the E3's and immediately felt an increase in power and idle quality and easier starts.
67CamaroRS/SS is offline
post #7 of 9 (permalink) Old Jan 26th, 09, 12:01 PM Thread Starter
Chris
Hatya's Avatar
Thanks Charlie, i may switch to them at some point.
Hatya
Daily Driver
Hatya is offline
post #8 of 9 (permalink) Old Jan 31st, 09, 10:46 AM
Ralph
[quote=zdld17;1145790]I like Autolites also, Might look at a 4275 Autolite. I never had problems keeping them clean.[/quote
loveoldchevys is offline
post #9 of 9 (permalink) Old Jan 31st, 09, 11:13 AM
Ralph
I am looking for a better spark plug, I have a 68 Camaro RS, 327 / 275 with a small cam, Holley intake , Holley 750 Daul line carb and still using points in the Dist. Would you recommond the Autolite 4275 spark plug for this engine.
